Where the heck does this hose go? And who left this loose?
I am doing a swap and have a small problem. I got the motor, but all the hoses are cut. I have a B16A1 and I need hoses to complete it, but how do I figure out what goes where and where to get them. I was going to go to Honda and ask to look at there computer and look and see if the 2000 Civic SI is set up the same way, but first I decided to ask the people. Seems most of you know more than me, so why not help me out.
Also, the TPS on my throttle body is broken. Can I use one from a DX? If not, will a 2000 SI work? How about a starter? I have a 99 Civic SI tranny to go with my new motor, but it doesn't have a starter. Can I use my DX or any B-Series starter?
Is there a site that breaks down a Honda motor or a swap? Or a 24-Hour tech line?
Are you putting this B16A into an 88-91 Civic or CRX? You can order a B16A suppliment manual from a UK Honda dealer - part number 62PR300C. Specify the "c" at the end for copy to save lots of $.
As for where to hook up the hoses, I assume you are refering to vacuum hoses. Everything is just like it was on your old motor. Only a few things need a vacuum signal - MAP, fuel press. reg., and purge/cut valve. The dashpot on the throttle body needs to get it's vac. signal from the plastic tube before the throttle body...
TheMostSadistic
Feb 25, 2003 04:02 PM
