Brake Master Cylinder question.
Old Nov 10, 2005 | 12:14 PM
SuperSlow's Avatar
Default Brake Master Cylinder question.
I have gotten this "new" brake MC from Ebay.
Does this look right? The piston does not stick out the end. Am I supposed to release the ring?
TIA.
Old Nov 11, 2005 | 09:45 AM
maroonaccord2.2's Avatar
Default Re: Brake Master Cylinder question. (SuperSlow)
No, the existing rod goes there. I did mine on my 4th gen, just make sure to prime the thing with DOT 3, then re-bleed the brakes. Follow the included instruction for MC, they seemed to work fine for me.
Old Nov 11, 2005 | 09:56 AM
SuperSlow's Avatar
Default Re: Brake Master Cylinder question. (maroonaccord2.2)
Do you mean that there is an existing rod in on the booster that will go there? Or is it missing a rod? Thanks.
Old Nov 11, 2005 | 03:04 PM
P_Adams's Avatar
If your car is a 5th Gen (I have no idea; since after being in here for GOD knows how long, you don't see fit to put the discription in your signature), the rod in question is part of the vacume booster (refer link for illustration).
I would have to ASSUME it's the same for all.
http://www.hondaautomotivepart...POWER
P
Old Nov 11, 2005 | 03:19 PM
deserthonda's Avatar
u r right P- all hondas as far as i can remember have the rod in the brake booster
JonasG93
18
Apr 21, 2015 07:22 AM
jmaze
Suspension & Brakes
Dec 5, 2009 08:39 AM
ferrallas
Sep 4, 2006 11:44 AM
SuperSlow
Nov 10, 2005 02:14 PM
mrduke
Apr 30, 2004 09:10 AM
