TRANNY CHANGES GEARS TO RUFF
Old Nov 10, 2005 | 12:04 PM
DESERTDIVA's Avatar
Default TRANNY CHANGES GEARS TO RUFF
CAR IS AUTOMATIC HOWEVER WHEN IM DRIVING SEEMS AS IF IT WAS STICK THE CAR CHANGES GEARS TO RUFF IT KIND OF FEELS AS IF I WAS LEARNING HOW TO DRIVE STICK.......I WAS TOLD I NEED A TRANNY ADJUSTMENT BUT WONDERING IF ANYONE HAS ANY OTHER SUGESTIONS.... CAUSE CAR ALSO FEELS A LITTLE SHAKY WHEN ITS RUNNING OR JUST SITTING (0N) WHEN I TURN THE A/C ON ITS EVEN MORE ROUGH ANY SUGGESTIONS TO THIS NEWBIE?
GREATLY APPRECIATE!!!!
Old Nov 10, 2005 | 02:11 PM
C_H_A_D's Avatar
Default Re: TRANNY CHANGES GEARS TO RUFF (DESERTDIVA)
ok turn the caps lock off. first what year is the accord? what trim? How many miles I think it could be a bad motor mount.
Old Nov 10, 2005 | 02:36 PM
BLKFLSH's Avatar
Someone may have put non-Honda fluid in the transmission. Do you know if this could have been done? If so, put some Honda trans fluid in, and it may help. If the change helps, you may have to flush the other fluid by changing it three times, driving it a short distance between each change.
Old Nov 10, 2005 | 03:09 PM
Stealthman80's Avatar
Default Re: TRANNY CHANGES GEARS TO RUFF (BLKFLSH)
dude my cars like that and the fluids perfect
Old Nov 10, 2005 | 03:14 PM
HondaMike17's Avatar
Default Re: TRANNY CHANGES GEARS TO RUFF (Stealthman80)
1994-1997 honda accords have common problems at high mileage of shifting very harsh, go out and get a bottle of Lubeguard conditioner and add it to your auto trans. fluid
will probably fix the problem, if it doesnt, wont hurt it a bit
Old Nov 10, 2005 | 03:50 PM
Default Re: TRANNY CHANGES GEARS TO RUFF (HondaMike17)
try it out and let me know how it works for you.. im currently getting into high mileage myself and i may start doing the same thing
Old Nov 10, 2005 | 05:09 PM
RnEpmc's Avatar
i just had my tranny rebuilt. it went out at 118xxx.... i miss the ruff shifting. i miss the old tranny all together... the car shaking may be a bad motor mount.
Old Nov 10, 2005 | 05:47 PM
Ross 2.0's Avatar
In a Junkyard near you.
Don't ever put an additive in a Honda transmission. If it's shifting rough it's because of a problem. Adding something to the fluid is like putting a band aide over a bullet wound. Depending on the year and the such a rough shift is usually caused by bad fluid or a solenoid problem (Linear shift solenoid is a usual culprit).
Old Nov 10, 2005 | 05:51 PM
Ross 2.0's Avatar
Also older accords have problems with the valve bodies getting clogged. That requires a teardown. (big bucks)
Old Nov 10, 2005 | 06:05 PM
C_H_A_D's Avatar
[QUOTE=DESERTDIVA]CAR ALSO FEELS A LITTLE SHAKY WHEN ITS RUNNING OR JUST SITTING (0N) WHEN I TURN THE A/C ON ITS EVEN MORE ROUGH /QUOTE]
did any of you guys read this. if it idles rough in park or Neutral the tranny is not the problem. I also doubt Even at a light In drive with a rough idle the tranny is too blame.
I think Check you mounts first.
Old Nov 10, 2005 | 06:11 PM
Ross 2.0's Avatar
Default Re: TRANNY CHANGES GEARS TO RUFF (NINJASWORD)
I was getting there. I was too busy dancing on my soapbox.
Old Nov 10, 2005 | 06:14 PM
edited because i did not fully understand what you said before, i saw rough shifting and jumped on it.
Modified by HondaMike17 at 8:16 PM 11/10/2005
Old Nov 10, 2005 | 06:49 PM
Stew Pidasso's Avatar
I'm betting it's a 4th gen accord with a bad engine mount.
Old Nov 15, 2005 | 08:24 PM
DESERTDIVA's Avatar
when driving (automatic) when it's ready to do its gear change it sord of feels like a little foward launch.... so i guess i should check my motor mounts then.....how would i know if one is bad should it be craked or bent.........? still confused.........car is 97 accrd dx with 91,000 miles also having the water pump and timming belt done along with a complete tune-up ngk plugs and wires rotor and cap to see if it helps a bit also had wheel bearings replaced anything else i should have done to it.........???
Old Nov 15, 2005 | 08:29 PM
YeuEmMaiMai's Avatar
Default Re: (DESERTDIVA)
Do this
1. check fluid level
2. check motor mounts (front and rear. the rear has a vaccume line)
3. add a can of lubeguard for imports.
1. self explanatory
2. use a friend and have them start the car and after applying the e-brake and with their foot on the brake put the car in gear. if the engine moves excessively, replace any broken mounts
3. do this right after a fluid change
Old Nov 15, 2005 | 08:44 PM
BLKFLSH's Avatar
Default Re: (YeuEmMaiMai)
Put ONLY Honda ATF Z1 in the trans. Nothing else.
Old Nov 15, 2005 | 08:54 PM
Default Re: (BLKFLSH)
oooops forgot about that............
Old Nov 16, 2005 | 12:40 PM
same thing here its like a little forward launch, you know there are trans places that will check it for free, I got mine checked and they said there was nothign wrong with it
Old Nov 16, 2005 | 02:29 PM
Schmitey's Avatar
Default Re: (Stealthman80)
I know the fifth gens (96 is a 5th gen right?, i always forget) have an electric motor mount that softens and stiffens up. Sounds like a likely culprit and doesn't sound cheap. Damn the advantages of having a stick just keep on mounting!
Old Nov 17, 2005 | 02:18 PM
DESERTDIVA's Avatar
does anyone know where the solenoid shifter is located at on this 97 accord dx im having the motor mounts checked later on today.
Old Nov 17, 2005 | 02:20 PM
DESERTDIVA's Avatar
the car'd idle is perfectly fine it;s just that whiplash i get everytime the car shifts thats annoying........?????????
Old Nov 17, 2005 | 02:36 PM
BLKFLSH's Avatar
When I first got my 4th gen I read the service manual, and it said that the throtle cable could be adjusted to control shift harshness. I adjusted and readjusted until I got tired of adjusting. After I had the car for a couple years I got used to it. You will too. It may take a while. Of course I don't know how bad yours actually is compared to mine.
Old Nov 17, 2005 | 08:47 PM
thechineseone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote"> I adjusted and readjusted until I got tired of adjusting. After I had the car for a couple years I got used to it. You will too. It may take a while. Of course I don't know how bad yours actually is compared to mine.</TD></TR></TABLE>
yeah, my 92 honda lx also has a jerky shift problem, which is quite uncomfortable sometimes. which brings to my question, you were talking about adjusting it. Does it really help? cause it didn't help after i drain and refill the tranny, which a friend told me could be the cause. Also, how would you adjust on a 92 honda accord lx, where's the location, thanks.
Old Nov 18, 2005 | 12:50 PM
Default Re: (thechineseone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thechineseone &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, my 92 honda lx also has a jerky shift problem, which is quite uncomfortable sometimes. which brings to my question, you were talking about adjusting it. Does it really help? cause it didn't help after i drain and refill the tranny, which a friend told me could be the cause. Also, how would you adjust on a 92 honda accord lx, where's the location, thanks.</TD></TR></TABLE>
funny I was just gonna ask the same question, whats this cable you speak of?
Old Nov 18, 2005 | 01:46 PM
BLKFLSH's Avatar
It's the one up behind the throttle body ( two like 10mm nuts on a threaded rod). But like I said, I adjusted it until I was blue in the face, so to speak, and it didn't change anything. They had a procedure for adjusting it, but I don't remember what it was. And the service manual went with the car when I sold it. Sorry. After about 2 or 3 years, you get used to it. haha
You can play around with it, if you like, just remember this. If it raises the idle too much you won't be able to get the trans out of park. Good luck guys.
