oil on spark plugs
Old Mar 10, 2002 | 01:59 PM
chromedome's Avatar
Default oil on spark plugs
what does this mean when you pull out your spark plugs and 2 of them have oil on them??????? i have a 93 ls 140000 miles,,,,doesn't burn oil or smoke out the tailpipe......
steve
xXx integra
Old Mar 10, 2002 | 02:40 PM
chromedome's Avatar
Default Re: oil on spark plugs (Teken)
guess i'll have to take of the valve cover and check them out
thanks....
steve
xXx integra
Old Mar 10, 2002 | 03:12 PM
confucius's Avatar
Default Re: oil on spark plugs (chromedome)
how much are the "O" rings?
i need to replace one of them. But since im gonna have to open up the valve cover and stuff, i might as well replace them all.
are they easy to replace?
Old Mar 10, 2002 | 03:17 PM
Tomakit's Avatar
Default Re: oil on spark plugs (confucius)
Takes 20min to replace them...I did it last week.
Each ring is $2-3 from the dealer.
Tom
Old Mar 10, 2002 | 03:29 PM
confucius's Avatar
Default Re: oil on spark plugs (Tomakit)
what about the valve cover gasket?
after u take off the valve cover, do u have to seal the gasket? or just leave it the way it is..........
Old Mar 10, 2002 | 04:58 PM
VTi NA's Avatar
Teken, how much is a tube of that stuff? They sell them at the dealers correct?
Old Mar 11, 2002 | 08:11 AM
GSRaCeRbOI's Avatar
damn $2-3 each? my dealer ripped me off then.. i paid like $5.75 each for the spark plug gaskets... i also got hondabond for the valve cover gasket especially around the contours/curves.. its needed there... since i had the valve cover open.. i did my valve adjustment too...
Old Mar 11, 2002 | 10:20 AM
incogNitto's Avatar
I've got a brand new valve cover gasket sitting here. When I pull off the valve cover to do a valve adjustment, should I use Honda bond, or does the new gasket cover me in this situation? I'm making a trip down to the parts department tomorrow so I might as well ask for some if it's needed.
BTW, Teken, are you enjoying that new PC?
-Chet
Old Mar 11, 2002 | 02:37 PM
GSRaCeRbOI's Avatar
Default Re: oil on spark plugs (Sleepy186)
you might as well get some hondabond to put on the perimeters especially the contours/curves of your new valve cover just to make sure it makes a good seal.. you dont wanna have to re=pop it open cuz its leaking/sprayin oil or something..
Old Mar 11, 2002 | 09:00 PM
confucius's Avatar
ok, i went to auto zone to purchase 4 new "spark plug gasket". The guy at the parts section told me, there isn't such a thing.
so, what is it called agian? o ring? spark plug seal? somthing-somthing?
thanks.
collkid
May 12, 2017 11:39 AM
BlueRex1020
Feb 8, 2007 09:17 PM
froger
Feb 3, 2005 12:39 PM
wizzards581
May 26, 2004 08:47 PM
elpermgrande
Oct 18, 2002 04:42 PM
