My 1/4 mile times....
I just got back from the track, here are my times, i'll put down the specifics for the best one. I was presently surprised at them.
1st run - 15.80 - missed 3rd gear
2nd run - 14.95 - yummy
3rd run - 15.24 - bad launch
4th run -
R/T ... .531
60' ... 2.503
330 ... 6.486
1/8 ... 9.745
MPH ... 75.38
1000 ... 12.537
1/4 ... 14.907
MPH ... 95.15
The mods I have was a fields sfc-vtec controller, and tire pressure was 23 psi, other then that all stock.
I figure, i get some drag radial and my time will improve since the fields mostly helps the high end power
4th run -
R/T ... .531
60' ... 2.503
330 ... 6.486
1/8 ... 9.745
MPH ... 75.38
1000 ... 12.537
1/4 ... 14.907
MPH ... 95.15
what does a vtec controller do, how much does it cost, and whats the install liike?
j/k. vtec controller changes the rpm at which vtec engages. something like an apex VAFC costs around 300 bucks. never installed one.
how the hell are you getting 14.95 with a basically stock GSR? I have a LSD, so im getting better 60' times (2.3) albit stock tires dont help
my only power mod is a CAI
but im only getting 15.1 and im shifting like a fast ****.
my only power mod is a CAIbut im only getting 15.1 and im shifting like a fast ****.
Installation on a vafc isn't too bad. It's tedious and requires care. Make sure you hook up the correct wires. A soldering iron is probably necessary.
Good times for a basically stock gs-r
Too be more specific, I took out my spare tire, the cardboard plate in the trunk, some of the panels (weight nothing), and also took out the antenna and wiper motor.
The tires i had were 14in steelies at 23 psi.
I set my v-tec crossover to 52 (shh, don't tell anybody), everything else is stock
I put my GSR in the 14 second club with a AEM CAI and a slight drop on stock tires (high 14.9). Since then I have added DC 4-1, Apex N-1, Skunk2 Manifold, Skunk2 Cam Gears, DC Short Throw, & VAFC and pulled the same time (low 14.9).
Clutch and Tires are crap now so I can't wait to have them replaced this spring and see what will happen then.
Good run.
Good run.
you 60' should be in the 2.2 range, you need to work on your launch or get better tires!
Yea, I know my 60 ft times sucked, i couldn't get them under 2.4 the whole day. BUT those were on steelies w/ about 10-15% tread left, on my Kumho's I got a 2.3 60ft time and a 1.8 60ft time (my guess the 1.8 time was a computer error) the last time i went to the track.
Drag radials are in the works, the 195/60/14 tires are bulging out the sides already so do you think I would need new rims?
hmmm...doesn't look right. That trap speed is awfully high for a stock GSR. I doubt the sfc-vtec controller gave you that much hp, it doesn't do much for a stock car. I don't wanna call bs cuz it's not impossible but that trap speed is too high for a stock GSR. Any weight reduction?
im calling B S that impossible , your telling me you car is stock with vtec controllerand the rest is stock theres no way you dropped a more than a half a second with just a vtec controler ecspecially with 2.5 60 ft
no way this is true
no way this is true
fully belivable
My best real time has been a 15.0 at an ok altatude durring a warm day. Ive only got an intake and exaust.
My best corrected time from 2600 feet to sea level is a 14.7 (it was a cold night)
i presume you tuned the sfc, right? even thought thas really fast for a stock gsr..
what mods do u have?
i pulled a 15.1 with a 2.7 60foot
14.8 with a 2.2 60 foot
14.6 with a 2.1 60 foot - my fastest ever
wierd
wierd
The only way that trapspeed of 95 mph is possible in a "stock" GS-R is under these conditions.
-removed resonator/modified stock airbox
-disconnecting the stock muffler or open header.
Many people do these things, and some how "forget" to mention them
If you hear of an outlandish stock time, 99% of the time, the driver did some "free mods" to their "stock" car.
