Drilling through CF hood?
get it done professionally..thats my tip...
drilling it wrong can cause it to crack and your gunna hafta be hella good at measuring if you plan to do it yourself...good luck tho..post some pics and some of your methods when your done..
If your hood cost less than $600 it's really just a fiberglass hood with a sheet of soft carbon fiber laminated on top. It's easy to drill and wont crack, but I don't think you should breath in the dust you'll be making.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">If your hood cost less than $600 it's really just a fiberglass hood with a sheet of soft carbon fiber laminated on top. It's easy to drill and wont crack, but I don't think you should breath in the dust you'll be making.</TD></TR></TABLE>
Yeah but the resin will still crack and chip off in big chunks if not carefull!!!
I drilled through mine and installed locks. Just be EXTREMELY CAREFUL. Go SLOWLY. use masking tape over where you drill and start with a very small size bit and work you up step by step. You can never be too careful when doing this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">use a dremel it will almost melt its way through, use the special drill bit that came with the dremel
very clever!
</TD></TR></TABLE>very clever!
