b20 build up gsr or si
Old Nov 10, 2005 | 04:13 AM
teamtwin's Avatar
Default b20 build up gsr or si
hey i have a ? just wondering what head is better to build a b20 vtec gsr or si
Old Nov 10, 2005 | 11:27 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: b20 build up gsr or si (teamtwin)
B16(Si) head. It flows way better than the GSR head from the factory
Old Nov 10, 2005 | 02:17 PM
dohcMONSTER's Avatar
Default Re: b20 build up gsr or si (black_dohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_dohc &raquo;</TD></TR><TR><TD CLASS="quote">B16(Si) head. It flows way better than the GSR head from the factory</TD></TR></TABLE>
hahaha i know 1 cfm more
check in the 92-00 civic FAQ's there is no difference
Old Nov 11, 2005 | 11:39 AM
teamtwin's Avatar
Default Re: b20 build up gsr or si (dohcMONSTER)
Old Nov 11, 2005 | 04:07 PM
pendejon's Avatar
actually, the gsr head has the intake ports sitting higher on the head, allowing the intake charge to create the "flow cone" around the valves a little nicer. that's stuff that may help in the long run
Old Nov 11, 2005 | 04:19 PM
2k.civic.si's Avatar
Default Re: b20 build up gsr or si (pendejon)
there is a flow chart from alaniz floating around comparing a b16 head to a gsr head...b16 outflowed it at mid lift and was about the same at high lift
Old Nov 11, 2005 | 10:29 PM
thehatchninja's Avatar
GSR head also has quench pads in the combustion chamber for a better burn pattern and slightly higher compression. GSR head is better than all other B-series heads IMO. But in reality....whichever one you find first is the one you should go with. There is not enough of a difference to worry about it.
Old Nov 28, 2005 | 01:59 AM
dc4rider's Avatar
Default Re: (thehatchninja)
i own a coulpe b16 heads and gsr head the b16 is better i dont care what the chart say cuz the heads they test it on is usaly ported and **** b16
GGcivicEG
40
Nov 7, 2016 01:33 AM
92_honda_hatch
Oct 5, 2006 11:16 PM
boostedek9
Mar 4, 2006 04:49 AM
nygsr
Apr 4, 2005 12:05 PM
