bout to start getting parts for my LS/VTEC... need to know if im missing anything.
Old Nov 9, 2005 | 10:32 PM
92integraVTECgsr's Avatar
Default bout to start getting parts for my LS/VTEC... need to know if im missing anything.
Ok.. Im about to start getting parts for my LS/VTEC Bottom End Build.
Here is what I have so far:
B18a1 Block
Golden Eagle LS/VTEC Dowel Pins for the VTEC Head
Golden Eagle LS/VTEC Oil supply line
JDM ITR STD Pistons w/ rings, and wrist pins
ARP Rod Bolts
ARP Head Studs
OEM LS Headgasket
OEM B18c1 Timing Belt
OEM B18c1 Waterpump
OEM B18c1 Timing Belt Tensioner
OEM Type R Oil Pump
OEM or ACL Crank and Rod Bearings
I plan on having the block hot tanked and honed.
Is it necessary to have the crank micropolished and balanced? if so, I will have that done too.
What about having the rods shot penned? what exactly is that?
And a few small misc. parts like seals, oil rings, etc...
How does all this sound? let me know if I am leaving anything else out.. Thanks guys.
Oh ya, and Hondata S100 for tuning.
Old Nov 10, 2005 | 02:51 AM
Runnerdown's Avatar
Sounds like a great setup so far. If the block is going to get honed see if the machine shop can use a finer grit stone like honda calls for. Most shops use like a 240 grit and honda says around 400. Also make sure the piston to wall clearance doesnt go above .001 -.0015 thou. Have the crank journals polished and cleaned the balance is really good on stock cranks....I have mine checked but they never need it. Use oem rings they seal very nicely.
Old Nov 10, 2005 | 08:19 AM
Default Re: (Runnerdown)
sounds good..
anyone know how much it costs to hot tank, hone, micropolished and balance a crank?
(approx. price for each procedure)
Old Nov 10, 2005 | 09:43 AM
miller.91.HB's Avatar
Default Re: bout to start getting parts for my LS/VTEC... need to know if im missing anything. (92integraVTE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">I plan on having the block hot tanked and honed.</TD></TR></TABLE>
Good idea to get the cylinders honed. It's a must when installing new pistons. The only thing that sucks about hot tanking a block is that it must be completely bare.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">Is it necessary to have the crank micropolished and balanced?</TD></TR></TABLE>
Not needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">What about having the rods shot penned? what exactly is that?</TD></TR></TABLE>
Again, not needed. Guys have been making great power on stock ls rods.
What head are you planning on using?
Modified by miller.91.HB at 1:13 PM 11/10/2005
Old Nov 10, 2005 | 11:46 AM
ghg78's Avatar
I NIKES
hot tanked=should be free if your having work done
honed=should be no more than 10-15 per hole
micro polished and balance=mine cost 100 even
Old Nov 10, 2005 | 11:55 AM
ne3ek's Avatar
Default Re: (ghg78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghg78 &raquo;</TD></TR><TR><TD CLASS="quote">hot tanked=should be free if your having work done
micro polished and balance=mine cost 100 even</TD></TR></TABLE>
that is a VERY cheap machine shop then lol.
m pirces were much higher than that for sure.
Old Nov 10, 2005 | 01:46 PM
ghg78's Avatar
I NIKES
Where i used to work we used him pretty frequently,so he gives me a break.
Old Nov 10, 2005 | 02:24 PM
Default Re: (ghg78)
sounds pretty good..
ya ive read shot penning isnt that important. they are used LS Rods but im putting new bearings and arp rod bolts.. so should they still be ok? and dont plan on reving past 8000.
Old Nov 10, 2005 | 02:42 PM
rfuentes29's Avatar
You need an ECU, P28 and OBD2 to OBD1 conversion harness.
Matthewhughes
Jan 31, 2014 08:32 PM
96redEKhatch
34
May 6, 2010 07:09 PM
InTheLBC20
Mar 27, 2010 04:24 PM
BOOSTEDgreeneg
Feb 15, 2006 03:42 AM
92integraVTECgsr
24
Dec 21, 2005 04:29 PM
