CHECK IT...my steering wheel begins 2 shake at....
somewhere around 75-80 as i increase it gets worse it feels...almost scary...i just installed a 21mm sway bar...and double checked everythin 2 b torqued 2 spec...ive searchd and got some good ideas i plan on tryn...but not sure if its the same prob im having...i did a tire rotation little while ago..and had a flat on 1 of my back tires(where if feels like the shakin is comming from)...i feel it strong through the steering wheel...ive heard to lift the car up after i unbolt the car and reinstall the wheels in the air because they didnt sit on the hub right thats why i feel high speed shake...i also heard to get all 4 tires rebalanced again...and also 2 do a alignment(which i havent had done in a long long long time) i do feel the car pull 2 a side at times so i am considering this...i doubt it has anythin 2 do w the bar...but i noticed it more after installing??!??....well any suggestions would b great...the shakin is begining 2 get 2 me...
....thanks
....thanks
"Wheel Alignment is often confused with Wheel Balancing. The two really have nothing to do with each other except for the fact that they affect ride and handling. If a wheel is out of balance, it will cause a vibration at highway speeds that can be felt in the steering wheel and/or the seat. If the alignment is out, it can cause excessive tire wear and steering or tracking problems"....i read this on a website...so my prob would b a wheel out of balance?...or could it still b my alignment
hmm its late here....n im tired...ill prob go get a alignment tommarrow and my wheels balanced....but hopefully in the AM goodol hondatech will have a solution for me....
you should do everything you said in your first post. no need for this thread really. you already know what you have to do.
replace shitty tire with a new one
get your wheels balanced.
get alignment.
done and done.
get alignment.
done and done.
h22pwr
Apr 12, 2006 06:46 AM
