CEL w/ Fields SFC-VTEC
Old Mar 10, 2002 | 12:22 PM
NXSpoon's Avatar
Default CEL w/ Fields SFC-VTEC
I have a 99 Si w/ a reprogrammed P28. Connected the Field's last night to the harness, soldered all connections, hooked it up as an OBD I ECU.
Started fine, VTEC control works, speedometer works, halfway through the drive, CEL comes on. I haven't had a chance to read the code, since it resets after turning car off and then back on, all connections are solid.
Ran car up and down rev range a few times, engaging VTEC. Anyone have an idea??
Old Mar 10, 2002 | 01:42 PM
B_CRUZ!'s Avatar
Default Re: CEL w/ Fields SFC-VTEC (NXSpoon)
this is typical. how did you hook up the map sensor connections? i hope you solderd it cause if its just twisted together with electrical tape around it, it will act up on you after a couple of minutes of driving. i suggest you solder all of the connections. in the mean time, if the light goes on again while driving, put your key in the acc position for a second and switch it back to on. don't turn it all the way like you are starting your car just flick it on on.
Old Mar 10, 2002 | 04:33 PM
NXSpoon's Avatar
All of the connections were soldered. When there were two wires from the SFC to be connected to one wire on the ECU harness, the 2 wires from the SFC were twisted together, then soldered together. Then a layer of solder was applied to ECU harness, then the SFC leads were soldered onto the ECU harness.
Old Mar 11, 2002 | 03:24 AM
NXSpoon's Avatar
TTT
titan74
Mar 25, 2014 10:37 PM
Preludes'R'Us
Jun 8, 2009 06:44 PM
liquidxEG
Feb 22, 2005 03:46 PM
JinDIESEL
Sep 24, 2004 02:06 PM
DarkBB4
Sep 8, 2004 10:43 AM
