b16a problems HELP!!!!!!!!!!!!!!!!!!!!
Old Nov 9, 2005 | 08:35 PM
ppl talk bout my old name's Avatar
Default b16a problems HELP!!!!!!!!!!!!!!!!!!!!
i just put a rebuilt b16a in my 88 crx and it ran fine i put 500 miles on it with out reving more than 4g but now i hit the red lined and after that it started maken a weird low pitch slugish noise from the exhaust and i thought it could have been a leak aroung the gasket but i have no idea can any body help me asap would like to get it back out on the street also i think i lost a little power and vtec got alot louder than normal and it sounds like it is skiping or jumping like my cluth is sliping but that is new too im so upset someone help me PLEASE
Old Nov 9, 2005 | 08:50 PM
SD_Lurker's Avatar
HT White Ops
Default Re: b16a problems HELP!!!!!!!!!!!!!!!!!!!! (ten second crx)
sluggish sound is not descriptive enough buddy. does it mis fire?? what are the characteristics??? please tell me more. i can give you my number and I can listen to it and I will tell you.
Old Nov 10, 2005 | 10:33 AM
Default Re: b16a problems HELP!!!!!!!!!!!!!!!!!!!! (nicks_jdmstyle_ef9)
like it sounds like a fart or some thing but it only sounds like it when its in gear but in nutral it sounds fine but any help would be nice
also it kinda sticks if you can get my drift like it fells like a brewak but im still moving and its pissing me off
Old Nov 10, 2005 | 12:06 PM
Contender25
Guest
Posts: n/a
Check you're dizzy/ignition coi/igniter/spark plugs/spark plug wires, also you're timing. Make sure you're throttle cable is adjusted right and is not stickin, i heard people should use a 90/91 integra throttle cable with b16a swaps.
Old Nov 10, 2005 | 01:02 PM
Default Re: (Contender25)
well thanks but i think it might be some thing alittle more serious than that but i will check it any way
Old Nov 11, 2005 | 03:43 AM
Contender25
Guest
Posts: n/a
Yeah like you're timing, maybe you got water in the motor, who knows. If it seems slower and it's poppin and **** then don't drive it.
Old Nov 11, 2005 | 10:36 AM
im not driven it it has power still but i think it might be my tranny any other options like but the whole motor runs fine but it dont pop like a vavle and it dont smoke at all but the exaust sounds alittle weak and it sounds like it would if you wear to pump your gas at in 5th gear at a slow mph its really weird i dont know and it is pissin me off
Old Nov 11, 2005 | 01:57 PM
Contender25
Guest
Posts: n/a
I really think you have either you're timing off, or you have water in you're motor. I had the same problem one time where it was off a little bit AND had a little water in the motor, and it kept makin that skippin pop sound you are tryin to describe.
Old Nov 12, 2005 | 12:12 PM
yea my exaust was un hooked but my check engine light goes on a 65 mph i think that is timming what do you think
juniorlx
Mar 12, 2012 11:29 AM
BuiltCivic99
Mar 24, 2010 10:30 PM
kalani5969
18
Aug 27, 2006 03:39 PM
B16A redline
Jan 18, 2005 10:49 PM
