Sqeaky steering noise
Old Nov 9, 2005 | 08:29 PM
HATCHingMN's Avatar
Default Sqeaky steering noise
Hey any of you guys have this problem,...?
while turning the steering wheel at low speed the steering sqeaks?
whay cause this problem and can I fix it?
Old Nov 9, 2005 | 08:38 PM
dcb16's Avatar
Default Re: Sqeaky steering noise (HATCHingMN)
need more info!! are u sure its the steering? does it squeek when driving low speeds and turning? have u checked ur p/s fluid? ect ect
Old Nov 9, 2005 | 08:39 PM
integra3586's Avatar
mine did that and it was the ball joints
Old Nov 9, 2005 | 08:42 PM
HATCHingMN's Avatar
Default Re: Sqeaky steering noise (integra3586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 &raquo;</TD></TR><TR><TD CLASS="quote">mine did that and it was the ball joints</TD></TR></TABLE>
how did you fix that?? new bushing??
Old Nov 9, 2005 | 08:43 PM
HATCHingMN's Avatar
Default Re: Sqeaky steering noise (dcb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 &raquo;</TD></TR><TR><TD CLASS="quote">need more info!! are u sure its the steering? does it squeek when driving low speeds and turning? have u checked ur p/s fluid? ect ect</TD></TR></TABLE>
PS fluid is full
It only sqeak when...say making turns in the parkinglot
Old Nov 9, 2005 | 08:47 PM
dcb16's Avatar
definitly check front steering and suspention components. rack boots, tie rod ends, and all those bushings. lets us know what u find out!
Old Nov 9, 2005 | 08:48 PM
check if lower ball joing boots are torn, if they are try to replace the boot and repack with grease, or u can just replace the whole ball join
Old Nov 9, 2005 | 08:49 PM
HATCHingMN's Avatar
I was hoping someone would know so I dont have to tear it apart
Old Nov 9, 2005 | 08:51 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 &raquo;</TD></TR><TR><TD CLASS="quote">check if lower ball joing boots are torn, if they are try to replace the boot and repack with grease, or u can just replace the whole ball join </TD></TR></TABLE>
I'll check on that tomorrow,
but I thought last last time I swap the tranny out ithe balljoint was still good though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">I was hoping someone would know so I dont have to tear it apart </TD></TR></TABLE>
no one will be able to properly diagnose your car with out seeing it
Old Nov 9, 2005 | 08:53 PM
HATCHingMN's Avatar
no one will be able to properly diagnose your car with out seeing it</TD></TR></TABLE>
I thought there might be someone here who have the same or samilar problem.
Old Nov 9, 2005 | 08:59 PM
erik92DA's Avatar
My 92 LS does that sometimes. Does it sound like the noise is coming from inside the car around the steering column? I think there was a service bulletin that addressed it, but i dont remember what the fix was.
tsunami77
Apr 20, 2008 01:30 PM
94BlueGSR
Dec 2, 2006 10:07 AM
1999gs-r
Jul 19, 2006 07:54 AM
Jay J
May 4, 2006 10:25 PM
Eskram
Jan 4, 2002 02:55 PM
