d16y8 has lots of blow by rings and headgasket look just fine
Old Nov 9, 2005 | 06:34 PM
pinche's Avatar
Default d16y8 has lots of blow by rings and headgasket look just fine
here is what is happening and what i have,
start the car and get lots of blow by coming out the breather or if i lift my oil stick lots out of there too, whether at idle or hauling *** even enough to spray oil onto my hood from my breather. i took my head off today and the head gasket( greddy 2mm) looks just fine and so do the walls of my sleeves.
i have a d16y7 bottom end with a y8 pnp head, cam, 2mm head gasket, i boost this thing pretty hard.
i plan on rebuilding this thing totaly, already have a new built head, but my motor i have now seem flawless. i have my pcv valve hooked up, i just have no clue were it can be coming from.... possibly valve seals or, i read it could be a clutch throw out bearing heating up???? could this be the problem. thanks a lot
Davis2
Feb 12, 2017 06:12 PM
Robotin
Mar 24, 2012 04:03 PM
guessohw
Sep 30, 2009 05:43 PM
thi3v3z
Jun 19, 2009 06:52 AM
pinche
Nov 10, 2005 01:23 PM
