B16, CTR Cams, Valve adjustment
Old Nov 9, 2005 | 04:25 PM
Earthworm Jim's Avatar
Default B16, CTR Cams, Valve adjustment
Question: Stock B16 with CTR cams about to go in, is the valve adjustment the same or different? If it's different then what should I do?
Old Nov 9, 2005 | 04:27 PM
Default Re: B16, CTR Cams, Valve adjustment (The_General)
help
Old Nov 9, 2005 | 04:29 PM
L8apex's Avatar
Valve lash spec should be the same regardless of what cam is in there.
Old Nov 9, 2005 | 04:31 PM
Default Re: B16, CTR Cams, Valve adjustment (L8apex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8apex &raquo;</TD></TR><TR><TD CLASS="quote">Valve lash spec should be the same regardless of what cam is in there.</TD></TR></TABLE>
Makes sense now that someone else has written it, it's not like the size of the cams are changing, right
SkoundrelUSA's Avatar
cute little bastard
Pretty sure its the same
Old Nov 9, 2005 | 04:34 PM
Default Re: B16, CTR Cams, Valve adjustment (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure its the same</TD></TR></TABLE>
BMX CRU
Old Nov 9, 2005 | 04:38 PM
handa's Avatar
My friend runs them the same specs.
Old Nov 9, 2005 | 05:20 PM
Default Re: B16, CTR Cams, Valve adjustment (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">My friend runs them the same specs.</TD></TR></TABLE>
Old Nov 9, 2005 | 05:54 PM
Padawan's Avatar
Darth ModerVader
That's completely false.
Old Nov 9, 2005 | 07:13 PM
L8apex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_General &raquo;</TD></TR><TR><TD CLASS="quote">
Makes sense now that someone else has written it, it's not like the size of the cams are changing, right </TD></TR></TABLE>
Actually the size of the cam IS changing, why else would you replace the stock ones? The closed spec or base circle stays the same. And seeing is how you adjust the lash when the valves are closed, it should be the same spec for whatever cam is in there.
Some cam manufacturers might recommend a different spec that may be proprietary, but OEM vs. OEM, I'm guessing it's the same.
Old Nov 10, 2005 | 12:35 AM
Some cam manufacturers might recommend a different spec that may be proprietary, but OEM vs. OEM, I'm guessing it's the same.</TD></TR></TABLE>
I meant new cams doesn't mean that I'd need a new block, they are getting fatter though. I should be alright though, thanks for the advice
mesonerz
Apr 4, 2008 01:32 PM
SPOON_FED_DC_2
Apr 4, 2005 09:33 PM
brixity
Feb 7, 2005 03:13 AM
B16Civic93
Nov 3, 2004 03:39 PM
USDMMARK
Apr 12, 2003 10:37 AM
