What would be my displacement if I..
Old Mar 10, 2002 | 10:28 AM
jdm-spec-eg's Avatar
Default What would be my displacement if I..
sleeved it to 84.5mm?
Old Mar 10, 2002 | 10:29 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: What would be my displacement if I.. (jdm-spec-eg)
Here's an idea.
Why don't you tell us what kind of engine you have first.
Old Mar 10, 2002 | 10:32 AM
Default Re: What would be my displacement if I.. (B18C-EJ1)
Oh ****, my bad!! B16A2.
Old Mar 10, 2002 | 10:33 AM
HXMan's Avatar
LMAO!!! B18C-EJ1 is right!
I think it is around 1.8-1.9 liters.
[Modified by HXMan, 1:34 PM 3/10/2002]
Old Mar 10, 2002 | 10:34 AM
B18C-EJ1
Guest
Posts: n/a
1736.16 cc's
Old Mar 10, 2002 | 10:35 AM
Thank you!! What is the formula to get the displacement?
[Modified by jdm-spec-eg, 7:35 PM 3/10/2002]
Old Mar 10, 2002 | 10:37 AM
B18C-EJ1
Guest
Posts: n/a
Pi*R squared, * # of cylinders, * Crank size in mm (stroke)
E.g.
3.1415* (42.25*42.25) * 4 * 77.4
[Modified by B18C-EJ1, 11:37 AM 3/10/2002]
Old Mar 10, 2002 | 10:40 AM
B18C, what would you do in my case. LS/Vtec or B16 sleeved? I have a CTR head to go on whatever block!
Please, your insight would be appreciated!
Old Mar 10, 2002 | 11:54 AM
B18C-EJ1
Guest
Posts: n/a
B16's are great for auto-x, but not much good for anything else. There just isn't enough torque compared to a GSR or LS even.
If you're thinking of doing a LS/VTEC or CRVTEC make sure you do your research. The engines were never designed to rev past 8k. So make sure you do a few things like balancing, Z10 crank girdle, etc......
That way you can be sure that your new engine will last a long time.
Import review is a good place to find dyno charts of different engines.
http://www.importreview.com
Jeff is a good guy too. He can answer a lot of LS/VTEC & CRVTEC engine questions.
HTH.
Old Mar 10, 2002 | 12:02 PM
I have built a LS/Vtec last year with much success. I am aware of what you have to do! I just figure I will want to rev it out to somewhere around 8300-8400. I have spoke with Jeff(Importreview) through emails and he said I will be good up to 8500.
I will be using ARP rod bolts and head studs. CTR pistons with a complete CTR head. I have a OBD1 Skunk 2 ecu. I have already purchased a brand new Vtec Oil and water pump. I just have to buy the Stainless line and misc parts.
I am in just a great debate of what to do cuz this is my daily driver. I need something to rely on day in and day out!
I have a GSR block girdle, can I use that?
Old Mar 10, 2002 | 12:29 PM
B18C-EJ1
Guest
Posts: n/a
You can use the GSR girdle, but you'll need to have the caps machined to fit.
You'll also need:
GSR pan
GSR pickup
GSR windage
GSR main bolts
Old Mar 10, 2002 | 01:56 PM
HXMAN says it is around 1.8-1.9
B18C says it is a 1.7
Which is it?
Old Mar 10, 2002 | 02:00 PM
Civic Hatch Boy's Avatar
New User
id go with jdm. he gave you an exact cubic centimeter answer. where as hxman said "i THINK.... " then he gave u a ballpark figure .. "1.8-1.9" which doesn't seem to precise.
Old Mar 11, 2002 | 10:13 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: What would be my displacement if I.. (Civic Hatch Boy)
Math doesn't lie CHB.
Pi times R squared, multiplied by the stroke gives you the volume of 1 cylinder. Multiply that by the # of cylinders, and divide by 1000. That will give you your total cubic centimeters.
GOLDBERG
Dec 12, 2015 01:10 PM
eddiecut
Sep 23, 2002 09:46 PM
Turbo_Teg
Sep 18, 2002 03:58 PM
LSBeast
13
Aug 24, 2002 01:13 AM
