wich one's in front and wich one's in rear ?
Old Nov 9, 2005 | 03:27 PM
twisted_jdm_b16's Avatar
Default wich one's in front and wich one's in rear ?
my lil bro purchased some coilovers . the spring rate on them are 350 and 450 . he has a 91 hatch . wich one's would you guy's recommend go in front and wich one's in the rear ?
Old Nov 9, 2005 | 05:23 PM
SD_Lurker's Avatar
HT White Ops
Default Re: wich one's in front and wich one's in rear ? (twisted_jdm_b16)
450 front 350 rear
Old Nov 9, 2005 | 05:27 PM
rsca_crx's Avatar
how long has he been driving? 450 in the rear will make it handle better. it also might make him crash.
Old Nov 10, 2005 | 12:09 AM
Default Re: wich one's in front and wich one's in rear ? (rsca_crx)
why do you say that it might make him crash if he puts the 450 in the rear ?
Old Nov 10, 2005 | 12:11 AM
Zaakro's Avatar
cuz they are way to big for the rear
Old Nov 10, 2005 | 12:14 AM
Tyson's Avatar
Which springs go up front?
GC normally designs their spring kits so that the front is stiffer. You can follow that, but ERS(springs) are interchangeable. So you CAN put the stiffer in the rear, it will alter the suspension by basically making the rear stiffer, which makes the car less understeer, which is generally more desirable for better handling performance. However, it *makes the rear stiffer*, and you will feel the difference since FWD cars have the center of gravity more towards the front, so the rear wheels rotate further from the CG than the fronts, thus are more sensitive to bouncing motion. Its up to you. I suggest you just follow what GC recommends, but if you are so inclined, cautiously try to swap them and see what you prefer.
http://www.norcalcrx.org/tyson/coilover.html
Old Nov 10, 2005 | 08:06 AM
cr-rex88's Avatar
I'd say 450 in the front and 350 in the the back to be safe.
Old Nov 10, 2005 | 10:20 AM
Outsane's Avatar
Default Re: wich one's in front and wich one's in rear ? (cr-rex88)
what coilover and shocks did your bro get?
Old Nov 10, 2005 | 12:45 PM
Default Re: wich one's in front and wich one's in rear ? (Outsane)
he just got some cheap ebay coilovers that say tommotorsport.com . that actually arnt bouncy and work well and cant complain about the price either ($45 shipped) .
Old Nov 10, 2005 | 01:17 PM
Outsane's Avatar
you should get some decent shocks to run with those coilovers..
your going to be underdampened
jond
Apr 12, 2004 07:19 PM
