ticking from the crank pulley
Old Nov 9, 2005 | 01:43 PM
brads94accord's Avatar
Default ticking from the crank pulley
over the last two weeks or so i have heard a ticking noise that has gotten progressively worse...thought it might be my valves but no its not it. it seems to be coming from my crank pulley. Has anyone else's crank pulley began to loosin over time? my car has 158,000 and i have never touched the crank pulley. im gonna hit it w/ the impact gun this weekend when i get my tools back from my buddy.
Old Nov 9, 2005 | 01:44 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ticking from the crank pulley (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">im gonna hit it w/ the impact gun this weekend when i get my tools back from my buddy.</TD></TR></TABLE>
Only real advise I can give you
Old Nov 9, 2005 | 01:48 PM
notoriousB's Avatar
I'd skip the impact gun and hit it with the torque wrench instead.
It could be your oil pump that's ticking (right behind crank pulley), do you have an oil pressure gauge installed? If so, how's it reading?
Old Nov 9, 2005 | 01:49 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ticking from the crank pulley (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">It could be your oil pump that's ticking (right behind crank pulley), do you have an oil pressure gauge installed? If so, how's it reading?</TD></TR></TABLE>
Water pump??? My buddies EP is doing this right now
Old Nov 9, 2005 | 02:09 PM
nah i dont have an oil pressure guage hooked up, i kinked the line when i was installing it so i never hooked it up. i thought the oil pump was a little higher up. whats the torque specs on the bolt?
the thing is when i look at the crank pulley while the car is on it looks kinda like its wobbling.
the oil pump was replaced back at the 90,000 tune up. well if it does go out im suppose to be picking up a parts car this weekend w/ a motor that has 108,000 miles.
Old Nov 9, 2005 | 03:27 PM
deserthonda's Avatar
i have seen a few crank pulley go bad,,,,,,,,try this,, get a big screwdriver pry on the ouetr part of the pulley and see if it start to separate from the inner part,, on the 0nes i have seen the rubber in between comes apart........
Old Nov 10, 2005 | 04:37 AM
notoriousB's Avatar
Default Re: (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">i thought the oil pump was a little higher up. whats the torque specs on the bolt?
the oil pump is right behind the crank pulley. torque is 181 ft/lbs for the pulley bolt.
definitely check desert's suggestion if the bolt isn't loose.
Old Nov 10, 2005 | 11:52 AM
i dont believe the bolt was loose i tried tightening it w/ the impact gun then the torque wrench..still makes the noise. where would i pry? the rubber part in the middle? i can't seem to get any leverage
Old Nov 12, 2005 | 02:44 PM
i hope it isn't my oil pump, that wouldnt be cool..well i just bought a parts car today w/ a good motor in it..might be swapping them out and build up my current block for the single cam moster.
Old Nov 12, 2005 | 07:20 PM
pry on the ouside part of the pulley , get a big scrwdriver and u can get leverage against the oil pan , and see if the inner part of the pulley where the rubber is moves away for the outer part
devilpuppy
Aug 30, 2024 09:15 AM
DARKTEG_
Aug 13, 2006 03:15 PM
twistedbydezign
Sep 24, 2005 02:10 PM
works909
Mar 3, 2005 11:42 AM
duececoupe2
Feb 28, 2005 08:04 PM
