Need help..low DYNO numbers
Old Nov 9, 2005 | 01:17 PM
moyosi's Avatar
Default Need help..low DYNO numbers
Hey guys...
A friend of mine has a civic 00 B16a2 and went recently to SCI motorsports to tune his car and got 170whp,116Tq but i think he could do more.
The setup is :
B16a2
Ported head, Multiangle valve job
Skunk 2 cams
INTAKE: DURATION @ 1mm 252º LIFT: 0.456"(11.5mm)
EXHAUST: DURATION @ 1mm 249º LIFT: 0.426"(10.8mm)
Arias Pistons
bore 3.209" compresion ratio 11.3, 283 gram piston weight
Eagle rods
cometic headgasket
AEM V2 CAI
DC headers
Hondata S200
2.5" catback
any recomendations about the setup or something helpful
thanks
Old Nov 9, 2005 | 01:28 PM
UncleD's Avatar
Default Re: Need help..low DYNO numbers (moyosi)
Is this motor OB 2?
Old Nov 9, 2005 | 01:29 PM
D-Rob's Avatar
Every dyno reads different.
168whp on that dyno may mean 175whp elsewhere.
...But besides that, the numbers look a little weak.
Do a compression and leakdown test...
- D-Rob
Old Nov 9, 2005 | 01:38 PM
92TypeR's Avatar
FSAE
Default Re: Need help..low DYNO numbers (D-Rob)
WTF is that lean spot on the first run!
The compression isn't that high, and the cams aren't that aggressive. He is sitting at a fairly conservative power output for that setup. I wouldn't think there is something wrong.
Old Nov 9, 2005 | 01:44 PM
moyosi's Avatar
Default Re: Need help..low DYNO numbers (clean rice)
yes is OBD2 w/ P28 OB1 + Jumper
Old Nov 9, 2005 | 02:04 PM
Dragline's Avatar
Dam you made 48 pulls
Old Nov 9, 2005 | 02:05 PM
Stefndogg's Avatar
Default Re: Need help..low DYNO numbers (92TypeR)
a decent header would prob help alot with that cam/piston setup
Old Nov 9, 2005 | 02:10 PM
Grand's Avatar
i dont think theres anything wrong either those numbers arent really lower than what id expect
Old Nov 9, 2005 | 02:25 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (LG_R32)
your a/f is pretty rich in the midrange. get that a/f to at least 14:1
Old Nov 9, 2005 | 02:47 PM
VtecKiDD's Avatar
Default Re: (Hella_JDM)
those are pretty decent numbers.
i have a very similar build:
00 B16 block stock .50mm overbore
M22X camshafts
AEBS intake manifold
AEM intake
Omnipower valves
milled head
Rocket valvetrain
Skunk2 camgears
JDM DC 4-1
11:1 compression
we got 173whp out of it 116TQ.
it made power to 8800rpms. We are working on getting a better header for it now.
funny thing is, we had a guy come through here with a JDM b16. he had CTR cams and a skunk2 manifold, and a sparks header and made 175whp. that kinda pissed me off, but that happens
Old Nov 9, 2005 | 04:42 PM
bstlude's Avatar
mike my white hatch (williams at the time) made 173 wi what i had done to it. I never want to race you with the window down again :\
rrace002
32
Nov 9, 2012 04:59 PM
hasty91ef
Aug 17, 2012 07:39 AM
ed..
Aug 4, 2011 09:56 AM
lovelife6431
Apr 25, 2008 09:01 PM
2.2SICKLUDE
Jul 5, 2005 11:37 AM
