Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit?
Old Nov 9, 2005 | 11:44 AM
Jonathan_ED3's Avatar
Default Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit?
The bolt is a 12x 1.25
I can't find a helicoil kit for it in stock anywhere, I can order one...but do you guys know how large of a hole needs to be drilled for these kits?
I'm trying to figure out if these stripped bolt holes are repairable with a helicoil.
The rear two are the ones that need to be repaired. The one closest to the engine is fine.
You can see how they are oblonged out a little. Looks like someone drilled the bolts out before.
Anybody know what size drill bit you predrill with for a 12 x 1.25 helicoil? I'm wondering if it's just big enough that these holes can be repaired!
Old Nov 9, 2005 | 01:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit? (Jonathan_ED3)
google M12x1.25 HeliCoil and the link has the drill sizes for each kit...
http://www.emhart.com/products...tm#MF
Although expensive,time-serts are alot more durable...
http://www.timesert.com
If you can't find the proper size in metric,
You could always use a standard size...
Modified by 88DXCRX at 5:11 PM 11/9/2005
Old Nov 9, 2005 | 01:40 PM
Surewin's Avatar
The drill size for a M12x1.25 HeliCoil is a 31/64".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">google drill tap sizes.. </TD></TR></TABLE>
Tap drill sizes? Do you know that is completely different then a HeliCoil drill size?
Old Nov 9, 2005 | 02:08 PM
88DXCRX's Avatar
Default Re: Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit? (Surewin)
opps..wasn't thinking clearly..sorry..
Old Nov 9, 2005 | 02:17 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit? (88DXCRX)
if you want to save money and time, try to get a tap and die set, the one that looks like a screw, and screw it in.
Tap and dies are always good for stripped lug nuts. the hexagon ones that is.
they sell screw drill bits with that twist in.
Old Nov 9, 2005 | 02:33 PM
Steve91's Avatar
You would have an easier time switching to SAE threads. 1/2" fine or coarse would work well. Bolts will be easy to come by too.
Actually, if you really want to do it up right. Tap it for SAE and install 3 studs.
Old Nov 10, 2005 | 07:26 AM
Default Re: Helicoil kit for transmission case bolts? 12 x 1.25 mm...what size drill bit? (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">if you want to save money and time, try to get a tap and die set, the one that looks like a screw, and screw it in.
they sell screw drill bits with that twist in.</TD></TR></TABLE>
I would do that...except the bolt hole is stripped out completely. There's no threads left at all. It's been slightly overbored.
Thanks for the help guys.
Old Nov 10, 2005 | 03:32 PM
NCchris's Avatar
Yeah, those holes look a little too fubared to use helicoils. FWIW, helicoil taps are known as STI taps for Screw Thread Insert. We use an insert at work called a keysert, its like the timesert except the wall is thicker. Would probably work. Does not require an STI tap, just a larger standard or metric size.
http://mdmetric.com/pdf/keysert.pdf
HTH
chris
Old Nov 10, 2005 | 07:15 PM
Chris,
It looks like the 12 x 1.25 kit should work for me.
Do you know any retail stores that sell these things?
Old Nov 10, 2005 | 07:59 PM
tyro's Avatar
Default Re: (Jonathan_ED3)
Try McMaster-Carr. http://www.mcmaster.com/
Search for helicoil.
Looks like 12x1.25 are $3.00 per pack of 10.
Old Nov 10, 2005 | 08:21 PM
if I went with helicoil kit, I'll need to double up on them.
The only problem with that is that I don't know what the external thread size is for a 12 x 1.25 kit. The hole is too large right now to accept a standard 12 x 1.25.
Maybe a 14 x 1.25?
Old Nov 11, 2005 | 12:18 AM
NikoZai's Avatar
Tap it for larger bolts I dunno, i just don't trust coil.
Old Nov 11, 2005 | 05:39 AM
NCchris's Avatar
Default Re: (tyro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyro &raquo;</TD></TR><TR><TD CLASS="quote">Try McMaster-Carr. http://www.mcmaster.com/
search for threaded inserts
They do small orders with a credit card
Don't try to double up on helicoils, bad idea.
HTH
chris
Old Nov 11, 2005 | 10:51 AM
Surewin's Avatar
Default Re: (NCchris)
So the hole is larger then 31/64"?
I have used helicoils on engine mounts and they worked fine.
Old Nov 13, 2005 | 06:28 PM
Default Re: (Surewin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surewin &raquo;</TD></TR><TR><TD CLASS="quote">So the hole is larger then 31/64"?
I have used helicoils on engine mounts and they worked fine.</TD></TR></TABLE>
I tried with a 1/2"...that's larger than a 31/64, so yes.
twentyhurtz
May 9, 2009 11:41 PM
jesterjess
Dec 24, 2008 12:11 PM
JRTegman987
Mar 4, 2007 05:13 PM
Jonathan_ED3
Welding / Fabrication
Nov 10, 2005 09:25 PM
d_mina
Sep 15, 2004 02:47 PM
