Is My Compression Fine for Skunk2 Stage 2 Cams ???
Old Nov 9, 2005 | 09:17 AM
Got Milk's Avatar
Default Is My Compression Fine for Skunk2 Stage 2 Cams ???
whats going on... this weekend im going to purchase skunk2 stage 2 cams and skunk2 valvesprings & retainers...i have a 2nd gen jdm b16a with 10.4 compression., is that compression decent for the cams??? or should i add a thicker headgasket to bump it up alittle bit
Old Nov 9, 2005 | 09:22 AM
jdm_ef9's Avatar
Default Re: Is My Compression Fine for Skunk2 Stage 2 Cams ??? (Got Milk)
10.4:1 is kinda on the low side for the stage2's. look into a "thinner" headgasket to raise the compression.
Old Nov 9, 2005 | 11:50 AM
Junkyard2000's Avatar
bump it up to at least 11...if not go with the stage1's
Old Nov 9, 2005 | 11:51 AM
Supernatural's Avatar
ctr cams
Old Nov 9, 2005 | 12:22 PM
Mohsin's Avatar
you could gain another 0.2 CR with high CR valves if they aren't uprated already. Thinner Gasket, both would increase CR to around 10.8:1 without milling
Old Nov 9, 2005 | 02:19 PM
Got Milk's Avatar
Default Re: (Mohsin)
o okay so do u think with the 10.8:1 compression it could handle the stage 2 cams ? also would i need to get aftermarket cam gears?
Old Nov 9, 2005 | 06:01 PM
Default Re: (Got Milk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Milk &raquo;</TD></TR><TR><TD CLASS="quote">o okay so do u think with the 10.8:1 compression it could handle the stage 2 cams ? also would i need to get aftermarket cam gears?</TD></TR></TABLE>
just strip 2 layers off your oem headgasket. That'll bump it up to 11
Old Nov 10, 2005 | 03:57 AM
Got Milk's Avatar
Default Re: (Junkyard2000)
u serious ? ^
Old Nov 10, 2005 | 07:24 AM
Got Milk's Avatar
bump
Old Nov 12, 2005 | 08:44 AM
paopao's Avatar
High lift cams "like" high compression, but that doesn't mean they need it to run. I had Skunk2 Stage 2's in my 10.1 GSR, and it made 180/130 on a Dynojet. All bolt ons. High comp = higher numbers.
Old Nov 12, 2005 | 09:06 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (paopao)
mill the head .030 s2s2 cams ******* love comp
Old Nov 12, 2005 | 09:09 AM
ninor's Avatar
Chances are you'll get some top power from them but you'll loose other places.
B16 does not like big cams, skunk 2 stg2 have itake valve closing at 49 ABDC, what this means is that you'll leak a lot of your already low compression away (known as dynamic CR if you care).
Ideally you are looking at 11.5:1 static comp on B18C for these cams and your B16 is different world compared to this.
B16 I would not put these cams before 12:1 staticCR at least, but hey that is just mu opinion...
Unless you want your car to putter around until it hits 7000+ I would suggest you look into CTR cams (which might be slight overcam anyway). You know what you get, quality is gueranteed and still gives you room to grow in the future...
Old Nov 12, 2005 | 09:22 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (ninor)
good info
Old Nov 12, 2005 | 09:57 AM
HBK GABE's Avatar
Default Re: (Hella_JDM)
just get the s2s2's, you know you will eventually be doing more work to your motor. Why buy ctr's now, to just have them removed down the road when you build your block or do headwork? s2s2
Old Nov 13, 2005 | 09:47 AM
Phatch99's Avatar
Default Re: (626Ebp_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 626Ebp_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">just get the s2s2's, you know you will eventually be doing more work to your motor. Why buy ctr's now, to just have them removed down the road when you build your block or do headwork? s2s2 </TD></TR></TABLE>
he's right... i'd get the s2s2 also... sooner or later your gonna want more power.
Old Nov 13, 2005 | 10:05 AM
boosted92's Avatar
Default Re: (Phatch99)
S2S2's (blox B's) made more power over S2S1's on a friends 9:1 compression turbo motor. The gains might have been higher with more compression, but they still made more power.
vitalik
Sep 15, 2006 01:32 PM
Death_to_Thieves
14
Dec 13, 2004 04:25 AM
1quickhatch
Sep 8, 2004 01:37 PM
EriK20
13
Apr 10, 2004 09:19 AM
