JDM b16 sir2 motor ecu?
Old Nov 9, 2005 | 06:09 AM
Slowass4dr's Avatar
Default JDM b16 sir2 motor ecu?
i wanna buy this 1990 integra. the car has a JDM b16 sir2 motor but he sais that the vtec doesnt engage because he needs the ecu. what kind of ecu will i need what car did it come in or is there a easier way to fix this?
Old Nov 9, 2005 | 06:41 AM
jdmitr's Avatar
Default Re: JDM b16 sir2 motor ecu? (B18wagon)
If the car is a '90, then you will need a obd 0 PR3 ECU. You will need to wire up Vtec pressure switch (2 wires), Vtec solenoid (1 wire), and the knock sensor (1 wire needs to be shielded and the braiding needs to be grounded near the ECU). Good luck!
Old Nov 9, 2005 | 05:09 PM
Slowass4dr's Avatar
Default Re: JDM b16 sir2 motor ecu? (jdmitr)
can any anyone else help me and inform me more on this motor where it came from, ect.
Old Nov 9, 2005 | 07:34 PM
loudassVTEC's Avatar
So I'm assuming the car is still OBD-0?? If so you'll need a obd-0 pr3 or pwo ecu. Then you'll need to find the pinouts, and wire up the VTEC solenoid, VTEC pressure switch, and the Knock sensor. Also the pr3/pw0 will be looking for a second o2 sensor. So you'll either need to weld in an o2 bung and put in a second o2, or you will need to splice the wire for the second o2 into the primary, which is what I did. I know this all sounds hard, but it sounds harder than it is. You just have to run some wires.
Old Nov 10, 2005 | 08:03 AM
jdmitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18wagon &raquo;</TD></TR><TR><TD CLASS="quote">can any anyone else help me and inform me more on this motor where it came from, ect. </TD></TR></TABLE>
What do you want to know, and how do you know it is from an SIR2? Take a pic and I will tell you what motor it is. If it is a OBD0 (1st gen) B16 it will be 160 hp to the crank. If it is a OBD1 JDM B16 then it will be 170 ttc. On the block does it say b16a, b16a3???
Old Nov 10, 2005 | 08:48 AM
Slowass4dr's Avatar
well like i said before the car is for sale and i want to buy it and the guy says its a jdm b16.... he is asking in the range of 1700, i dont whant to get in a car thats too hard for me to fix. look at the car here:http://hondamarketplace.com/zerothread?id=1425928 tell me what u guys think
Old Nov 10, 2005 | 10:35 AM
1700? Buy it! It'll take like 200 bucks maximum to get the VTEC working. Those blades look hott on the DA, and I might just have to get some for mine!
Old Nov 11, 2005 | 10:39 AM
Slowass4dr's Avatar
Default Re: JDM b16 sir2 motor ecu? (loudassVTEC)
bump for more advice before i buy it
Old Nov 11, 2005 | 06:29 PM
jdmitr's Avatar
Well he has no pics of the engine. I would get some first!
olskoo_Dude
Feb 3, 2012 10:26 PM
pro_status
Aug 29, 2008 07:20 PM
.M.
Jul 13, 2005 10:54 PM
mengy007
Sep 6, 2004 03:06 PM
Hybridize
Oct 17, 2003 11:37 AM
