Valve Clearance/Adjustment Specs for ZEX 59300 in a D16Z6?
Old Nov 9, 2005 | 05:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Valve Clearance/Adjustment Specs for ZEX 59300 in a D16Z6?
Pretty self explanatory.
I'd imagine you'd need to adjust the valves to different specs than stock when running the Zex "severe street" cam, yet they have no info about it on their site.
Any help?
Old Nov 9, 2005 | 06:15 AM
blaze the chemi's Avatar
Default Re: Valve Clearance/Adjustment Specs for ZEX 59300 in a D16Z6? (B18C5-EH2)
https://honda-tech.com/zerothread?id=665439
There is a .pdf on the page about two posts down, but my restrictions here at work don't allow me to pull it up. Either that or the damn link doesn't work anymore.
Hope this helps.
Old Nov 9, 2005 | 06:32 AM
ccjustin's Avatar
I thought with that cam you needed to run their new valve springs and retainers. with the 59100 you could leave everything stock, and just re-adjust to stock valve clearence. not sure, I was looking into that cam for my y8
Old Nov 9, 2005 | 06:55 AM
zeroice's Avatar
Default Re: Valve Clearance/Adjustment Specs for ZEX 59300 in a D16Z6? (ccjustin)
its advised to change them out, but if you really research its mainly if you plan on revving the **** outta your motor. If your gonna rev to 7k and no higher really, you will be fine with just the cam
Old Nov 9, 2005 | 07:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Valvetrain isn't being done as the guy who owns the car isn't planning on revving over 7000rpm or so.
...unless it dynoes peak whp above that.
Old Nov 9, 2005 | 07:46 AM
Luserkid's Avatar
I would just call the company. Better then anyone on here thats for sure.
Old Nov 14, 2005 | 04:13 PM
NonovUrbizniz's Avatar
Loved
http://www.compcams.com/Techni...1.asp
It's on their site
Intake:.007
Exhaust:.009
Old Nov 14, 2005 | 05:34 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Valvetrain isn't being done as the guy who owns the car isn't planning on revving over 7000rpm or so.
...unless it dynoes peak whp above that.</TD></TR></TABLE>
I have a friend who has the 59300 and he doesn't rev pass the rev limit nor does he uses the upgraded valve springs. Two years in the making and no issues. He adjusted it to what comp cams recommend which is IN .007/ EX .009 It sounds loud by that's expected from a performance cam.
Old Nov 14, 2005 | 06:07 PM
igo4bmx's Avatar
Default Re: Valve Clearance/Adjustment Specs for ZEX 59300 in a D16Z6? (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend who has the 59300 and he doesn't rev pass the rev limit nor does he uses the upgraded valve springs. Two years in the making and no issues. He adjusted it to what comp cams recommend which is IN .007/ EX .009 It sounds loud by that's expected from a performance cam. </TD></TR></TABLE>
anyone have lash specs for the d16y8 version?
Im assumign its the same
Pfieff
Jan 21, 2009 12:14 PM
user 98292739
16
Sep 21, 2006 09:28 AM
CrXr89Si
Feb 17, 2004 11:14 PM
