which cams on this 1.8l ls/v?
Old Nov 9, 2005 | 01:23 AM
TURBL0W's Avatar
Default which cams on this 1.8l ls/v?
-usdm itr pistons
-b16 head
-2 layer head gasket
-itr intake manifold
-68mm throttle body
-rmf narrow design header
-stock valves
-roughly a little over 11:1 for compression
Which would be a good street cam while at the same time have a killer top end. reving pass 8k to get most out of the cam should't be a problem since i'll be using the arp rod bolts. What do you think? or is there better out there? I know the pro1s beat m22 down low and m22s picked up power on top but that was on a higher compression motor. How will these cams perform on this compression?
Old Nov 9, 2005 | 10:59 AM
gt35r's Avatar
Default Re: which cams on this 1.8l ls/v? (lsvtec_power)
go with ROCKET. friend made 204 on stock itr motor
Old Nov 9, 2005 | 04:42 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: which cams on this 1.8l ls/v? (gt35r)
They are just asking for M22s
Old Nov 9, 2005 | 04:57 PM
DOMKID's Avatar
Default Re: which cams on this 1.8l ls/v? (Ace$nyper)
JUN III or Skunk2 Stage 2.
Proven profile.
Old Nov 9, 2005 | 05:00 PM
PURPLETERROR aka BIGMATT's Avatar
m22xx or pro2's
Old Nov 9, 2005 | 08:30 PM
ShaunRR's Avatar
HT White Ops
Community Builder
From what you describe, you might like the M22xx instead of the M22x cams. You should also be thinking about headwork at this stage.
Old Nov 16, 2005 | 07:05 AM
TURBL0W's Avatar
Default Re: which cams on this 1.8l ls/v? (rochesterricer)
Do the m22s beat skunks2 cam up top?
Old Nov 16, 2005 | 08:58 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Generally, yes.
nate_2k5
Nov 6, 2007 12:31 PM
digital sol
Jan 4, 2006 11:04 AM
JFG Kevin
30
Mar 24, 2005 11:44 PM
96tegls
Oct 15, 2004 02:44 PM
Mike95lude
Aug 20, 2002 11:31 PM
