B21 crank
Old Mar 10, 2002 | 07:25 AM
SCsol's Avatar
Default B21 crank
hey there guys im putting a B21 crank in my B20 what rods do i use for this LS costume what rods and has any one ever done thiss before and if so how well did it work
Old Mar 10, 2002 | 09:41 AM
HCrip's Avatar
Default Re: B21 crank (lowsol)
It's been done before, but you need some machining done to the crank. And the rod length is going to be custom. Lot's of money to put this in, and also, your rod to stroke ratio is going to suck. Check out Endyne's site for more info.
Old Mar 10, 2002 | 09:46 AM
The_Head's Avatar
Which B20 are you talking about, the late 80's prelude motor, or the one in the CRV?
Why arent you keeping the stock crank?
Old Mar 10, 2002 | 10:27 AM
B18C-EJ1
Guest
Posts: n/a
Boy if you're doing what I think your doing you need to use 134mm rods.
Stock LS rods 137mm
Stock LS crank 89mm
Stock B20A crank 95mm
95-89 = 6/2 = 3mm
137 - 3 = 134mm rods.
134/95 = 1.41 rod ratio.
I hope you don't plan on reving this past 7k rpm.
Old Mar 10, 2002 | 11:17 AM
TurboMiata's Avatar
Default Re: B21 crank (B18C-EJ1)
Ew....and I thought the rod/stroke ratio in the Mazda BP engines was shitty....
Why not just use an H22a if you despirately need all that displacement?
Old Mar 10, 2002 | 11:51 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: B21 crank (TurboMiata)
Seriously, at that point, I'd go H22.
bzyq2001
K Series
Feb 13, 2010 06:05 AM
gimmethayayo
Nov 8, 2009 12:09 PM
[Ennis_D]
May 14, 2007 02:34 PM
ItsSlow
May 30, 2006 05:54 PM
love2xlr8integra
May 2, 2004 08:00 PM
