Price of Clutch
Old Nov 8, 2005 | 09:32 PM
jonzel's Avatar
Default Price of Clutch
My mechanic told me he would replace my clutch master cylinder, slave cylinder, and clutch for $1100. (95 integra)
I thought that price sounded a little high.
Does anyone know what a fair price for these repairs would be?
Old Nov 8, 2005 | 10:45 PM
tvman's Avatar
Default Re: Price of Clutch (jonzel)
im gessing that sounds about right...im pretty sure replacing the whole clutch would cost around a g...master cylinder is around 100 n slave is around 75 or osmething i dont remember...unless you do it yourself itd b a lot cheaper
Old Nov 8, 2005 | 11:00 PM
SYTFU Tommy.'s Avatar
Default Re: Price of Clutch (tvman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">im gessing that sounds about right...im pretty sure replacing the whole clutch would cost around a g...master cylinder is around 100 n slave is around 75 or osmething i dont remember...unless you do it yourself itd b a lot cheaper</TD></TR></TABLE>
wow wat kind of clutch are you replacing?! 1 grand is a lot for a new clutch + the labor
Old Nov 8, 2005 | 11:23 PM
Platinum Playa's Avatar
you should probably try doing your clutch yourself. there is an article on team-integra.net the clutch maser cylinder can be rebuilt so you can try looking into that.
Old Nov 8, 2005 | 11:46 PM
Greddy Dantegra's Avatar
what kind of clutch the guy is giving u? for $1100? come to me... i'll get you a stock EXEDY CLUTCH for under $100 and the master cylinder for under $200.... If you live around the new york area i'll help u install it in for $100 so a grand total of $400 =P
Old Nov 9, 2005 | 12:08 AM
bg-33p's Avatar
Default Re: Price of Clutch (dvs gsr)
ya.. thats too much money, all those parts you listed will probably cost u 500 for good parts. and i guess labor is a lot too..try replacing the clutch urself.
Old Nov 9, 2005 | 05:15 AM
shamoo's Avatar
Will you make something up for me please?
Definitely too expensive. Clutch/tranny work is not "easy" per se, so a run of the mill garage mechanic will charge you more than a tranny specialist. Did you try going to a transmission-only place such as Aamco? They should do the clutch for you for about $350 or so.
The slave/master cylinder should be an easy job for you to do yourself. You can get them new at any autoparts store, or even OEM used here on HT.
If you have the means/space/tools/time, then I highly recommend you try to do this yourself. You will learn a lot in the process, not only how to change a clutch, but how things work, and where everything is.
Old Nov 9, 2005 | 06:15 AM
tvman's Avatar
Default Re: Price of Clutch (shamoo)
my cuzon told wen he replaced his whole clutch it ran him around 1g...i was assuming itd b the same for tegs...
Old Nov 9, 2005 | 06:52 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">my cuzon told wen he replaced his whole clutch it ran him around 1g...i was assuming itd b the same for tegs...</TD></TR></TABLE>
Why do you type/speak like that?
What do you mean when you say "his whole clutch." Did he replace the pressure plate and the clutch/friction disc along with the related bearings? Add to that the resurfacing of the flywheel, and that's what's included in a standard clutch replacement.
$1000 is waaaay too much.
Old Nov 9, 2005 | 07:03 AM
blackdelslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">im gessing that sounds about right...im pretty sure replacing the whole clutch would cost around a g...</TD></TR></TABLE>
let me guess.. you heard that on t.v.
Old Nov 9, 2005 | 07:17 AM
Integra_drk's Avatar
i would say that is pretty high, i got slave and master cylinders replaced, new clutch and flywheel installed for just over $900.
Old Nov 9, 2005 | 07:26 AM
BonB's Avatar
Default Re: Price of Clutch (Integra_drk)
try doin it urself, thats the cheapest way
egkwhy08
Nov 9, 2008 09:35 PM
Felt.2
Aug 13, 2006 03:47 PM
s1ngle
13
Sep 21, 2005 12:01 PM
akteamster
10
Aug 13, 2004 04:13 PM
