Stock gsr Sleeves
Old Nov 8, 2005 | 09:13 PM
EM2Civic's Avatar
Default Stock gsr Sleeves
With the success of stock sleeves i'm thinking of going with pistons and rods to hit my desired power goals (400-450whp). What i'm wondering other than a compression and leakdown test how can I know what condition they are in? It's a jdm block so you never know with the mileage (it's suppose to be around 90k-100kms by now~).
Old Nov 8, 2005 | 09:16 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: Stock gsr Sleeves (EM2Civic)
it can be hard to tell the condition of the stock sleeves rele. other than compression test and leak-down test, pull the motor apart and inspect the sleeves with your eyes!
Old Nov 8, 2005 | 09:47 PM
fmfkid250's Avatar
1 stock block isent as good as the next........
its prob worth spending the loot if u have it to get the sleeved block
Old Nov 8, 2005 | 09:52 PM
EikoU's Avatar
Since the block probably has high mileage just send the block to a machine shop to get honed..thats what I did with my ls block..stock sleeves ls/vtec turbo hoping for 400-450whp on c16..made 311 on 12psi so far and motor is running good..
Old Nov 9, 2005 | 01:43 PM
EM2Civic's Avatar
Default Re: Stock gsr Sleeves (bxjdmhatch)
Pretty much what i thought other than ripping it apart you can't really tell the wear. That's what i'm debating right now, pistons and rods on stock sleeves or built block.
Old Nov 9, 2005 | 02:55 PM
simike's Avatar
Don't go by a visual inspection. When I built my block I talked to several engine builders here on HT. They all said for the best results bore it .5mm over. This will give you a fresh surface for the rings, insure that the bore is round and not egg shaped and the longest possible life.
Old Nov 9, 2005 | 03:28 PM
EikoU's Avatar
Default Re: Stock gsr Sleeves (simike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simike &raquo;</TD></TR><TR><TD CLASS="quote">Don't go by a visual inspection. When I built my block I talked to several engine builders here on HT. They all said for the best results bore it .5mm over. This will give you a fresh surface for the rings, insure that the bore is round and not egg shaped and the longest possible life. </TD></TR></TABLE>
lets say ur using a stock bore block, stock bore pistons and u bore it .5mm over, it won't effect the pistons/rings in anyway?
Old Nov 9, 2005 | 04:08 PM
11SEC CIV's Avatar
i've had 2 motors w/ stk sleeves
get a good tuner
Old Nov 9, 2005 | 05:15 PM
simike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bxjdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">
lets say ur using a stock bore block, stock bore pistons and u bore it .5mm over, it won't effect the pistons/rings in anyway?</TD></TR></TABLE>
Yes it will effect the piston to wall clearance. You will need to step up to 81.5mm pistons and rings if you bore it .5mm over.
Old Nov 10, 2005 | 04:04 PM
EM2Civic's Avatar
Default Re: Stock gsr Sleeves (12SEC CIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">i've had 2 motors w/ stk sleeves
get a good tuner </TD></TR></TABLE>
I have no doubt in my tuner (evans tuning, aiming for 400-500whp) but if my block is in bad shape i can do nothing about it but sleeve/hone.
Old Nov 10, 2005 | 06:48 PM
simike's Avatar
You will be very happy with the results if Jeff tunes your car.
Old Nov 10, 2005 | 08:17 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simike &raquo;</TD></TR><TR><TD CLASS="quote">You will be very happy with the results if Jeff tunes your car. </TD></TR></TABLE>
WSA
Jun 29, 2012 07:04 AM
beyondstock
May 8, 2009 07:04 PM
hott95ej2
Sep 5, 2005 07:04 PM
