Smoking, b18c1.. story inside. HELP please
I put the motor in, it starts up, and runs really rough, this motor has not been ran for a year+ been sitting in a garage. Yesterday i pulled the plugs out, not only was there oil in the intake manifold, there was oil on the spark plugs. I bought a new head gasket, because i used the old one although it was in good condition thought i could get by.. put the new one one, and cleaned out all the plugs, bought a new pcv valve. Yesterday it really sounds like its miss-firing, i figured it would because of the oil on the plugs.. not getting good enough spark. Again i think that is why its running rough, but i don't know why there is oil.. new headgasket, i also bought new valve cover seals.. no dieffernce. The motor is a 99' Gsr swapped into a 95 vx. I have hondata, but put the stock p72 in there, because the car came w/ a turbo set up.. but i am converting it to n/a for emissions.. till i can get it licensed and tuned ect ect. I bought a used block off of a forum, because last blocks sleeves were toast from the turbo.. that block is off a 95 gsr. Any ideas would really be helpful im stuck, and starting to get upset! ty in advance
u need to do a compression test and a leakdown test. go here for how to do them. come back n update us when u get the results.
http://www.c-speedracing.com
