which ac bracket to use for b series/ek
Old Nov 8, 2005 | 08:23 PM
eknorcal's Avatar
Default which ac bracket to use for b series/ek
hey guys i'm not really sure on this.. i'm doing a gsr swap on my 96 hb with stock condensor.. which ac bracket do i need? my friend told me to get one off of a del sol b16. is that correct? any other ones i can use?
Old Nov 8, 2005 | 08:47 PM
eK9aT10pSi's Avatar
Default Re: which ac bracket to use for b series/ek (eknorcal)
any b-series will work.
Old Nov 8, 2005 | 08:51 PM
eknorcal's Avatar
Default Re: which ac bracket to use for b series/ek (eK9aT10pSi)
oh really? so i can just use the 97 GSR ac bracket for my 96 hb ac condensor and it'll bolt straight up?
well i need more info guys.. thanks
Old Nov 8, 2005 | 08:52 PM
pdiggitydogg's Avatar
^no
You will need a mount from a p54 del sol vtec (b16a3, not p30 b16a2) OR a p7j from a crv (apparently, you cannot use p/s with this mount)
If youre using a b series compressor, you can use any other b mount.
Old Nov 8, 2005 | 09:05 PM
eknorcal's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">^no
If youre using a b series compressor, you can use any other b mount.</TD></TR></TABLE>
thank you pdiggitydogg for making this clear.. i always thought that the si b16a2 mounts would work but i guess not.. so maybe i'll go get a p7j from a crv since i heard it'll be cheaper.. plus, i aint using powersteering so it doesnt matter to me. thanks a lot though
Old Nov 8, 2005 | 10:07 PM
WhiteNess's Avatar
Default Re: (eknorcal)
you can also use a p30 off a 2000 si and the single cam ac will bolt up with 2 bolts
Old Nov 8, 2005 | 10:56 PM
FuNkDrSpOt's Avatar
Default Re: (WhiteNess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteNess &raquo;</TD></TR><TR><TD CLASS="quote">you can also use a p30 off a 2000 si and the single cam ac will bolt up with 2 bolts</TD></TR></TABLE>
in other words, just get a p54
Old Nov 9, 2005 | 10:41 AM
eknorcal's Avatar
Default Re: (FuNkDrSpOt)
thanks a lot!!
ferio_boy
Mar 26, 2008 05:52 PM
SyDuck
Jul 16, 2006 12:34 AM
Moe_Mentum
May 25, 2006 07:11 AM
JDMFreak
Oct 14, 2002 07:28 AM
Sleepin'
Apr 12, 2002 11:33 PM
