which ac bracket to use for b series/ek
hey guys i'm not really sure on this.. i'm doing a gsr swap on my 96 hb with stock condensor.. which ac bracket do i need? my friend told me to get one off of a del sol b16. is that correct? any other ones i can use?
Re: which ac bracket to use for b series/ek (eK9aT10pSi)
oh really? so i can just use the 97 GSR ac bracket for my 96 hb ac condensor and it'll bolt straight up?
well i need more info guys.. thanks
^no
You will need a mount from a p54 del sol vtec (b16a3, not p30 b16a2) OR a p7j from a crv (apparently, you cannot use p/s with this mount)
If youre using a b series compressor, you can use any other b mount.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">^no
If youre using a b series compressor, you can use any other b mount.</TD></TR></TABLE>
thank you pdiggitydogg for making this clear.. i always thought that the si b16a2 mounts would work but i guess not.. so maybe i'll go get a p7j from a crv since i heard it'll be cheaper.. plus, i aint using powersteering so it doesnt matter to me. thanks a lot though
Re: (WhiteNess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteNess »</TD></TR><TR><TD CLASS="quote">you can also use a p30 off a 2000 si and the single cam ac will bolt up with 2 bolts</TD></TR></TABLE>
in other words, just get a p54
