91 Civic Dx d16y8 Swap
I Have a d16y8 motor Obd 1. My Cars a 91 Civic Dx.
I was wonder if I should just use a full obd 1 d16y8 harness with p28 Ecu. Would that be fine or do I make mine obd 0 to obd 1 from rywires.
Link for the harness obd 0 to obd 1:
http://rywire.com/store/produc...14153
I need some feed back on this. I want to do this right the first time.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">You need to use your engine harness, that's what I do know, as the mpfi ones for example the 91 Civic SI are not compatible.</TD></TR></TABLE>
So i need to do the rywire Change over with my d15b2 harness and the d16y8 harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvzero0 »</TD></TR><TR><TD CLASS="quote">So i need to do the rywire Change over with my d15b2 harness and the d16y8 harness?</TD></TR></TABLE>
You first need to convert to MPFI, I do know that. I don't know anything about obd1, so lets let someone else chime in here.
You first need to convert to MPFI, I do know that. I don't know anything about obd1, so lets let someone else chime in here.</TD></TR></TABLE>
I know i have to convert to MPFi thats a given.. I just want to know about the wiring with the d16y8 harness and the d15b2 harness.
i was going to do the same thing, but sold my car. you need to convert to mpfi then use the rywire kit for dx to obd1. they also have the mpfi kit as well i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trigger69 »</TD></TR><TR><TD CLASS="quote">i was going to do the same thing, but sold my car. you need to convert to mpfi then use the rywire kit for dx to obd1. they also have the mpfi kit as well i think.</TD></TR></TABLE>
for 300 bucks... i'll do the mpfi myself
yeah you need to buy a mpfi conversion kit install it and then a odb1 conversion kit and install it then you'll be able to swap the engine without problems
I can do the mpfi for 50$ myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvzero0 »</TD></TR><TR><TD CLASS="quote">for 300 bucks... i'll do the mpfi myself
Someone told me it's just a little more than running 2 wires. That sounds like it's not too bad at all. Take slow steps and it won't be bad at all.
</TD></TR></TABLE>Someone told me it's just a little more than running 2 wires. That sounds like it's not too bad at all. Take slow steps and it won't be bad at all.
Someone told me it's just a little more than running 2 wires. That sounds like it's not too bad at all. Take slow steps and it won't be bad at all.</TD></TR></TABLE>
Ya
http://tech.hybridgarage.com/t...g.htm
Ya
yeah, if you want to do the DPFI to MPFI yourself that's cool.
You'll still want the ECU jumper for sure, pin the distributor plug with the OBD1 plugs.
Remember that you barely need to cut anything, de-pin anything you can.
Wrench6
18
Jul 4, 2015 10:50 AM
Dandada
Nov 26, 2012 01:25 AM
93civicjaydm
Nov 10, 2006 11:36 AM
