Wheel balance problem, or something else?
Old Nov 8, 2005 | 05:14 PM
Sprockets's Avatar
Default Wheel balance problem, or something else?
I went on the highway today for the first time in about a month. Although I wasn't accelerating quickly, it didn't feel particularly smooth. At one point I boosted lightly in 5th gear at about 80mph, and the front end shuddered badly under acceleration. After I let off, it went away.
Is it possible for there to be a wheel balance problem that occurs only after a certain speed, and just under acceleration? I highly doubt it's my motor mounts, because the bottom 3 are only a few months old from Inline Pro. An engine swap was done several months ago, btw. Any ideas would be appreciated, thanks!
P.S. Using stock 15" 99-00 Si wheels and Falken Ziex 512 205/50/15 tires.
Old Nov 8, 2005 | 05:43 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel balance problem, or something else? (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible for there to be a wheel balance problem that occurs only after a certain speed</TD></TR></TABLE>
...yes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A &raquo;</TD></TR><TR><TD CLASS="quote">and just under acceleration?</TD></TR></TABLE>
...no. A wheel balance problem may only be noticeable at certain speeds, but wouldn't happen only under acceleration. Sounds drivetrain-related, rather than wheel/tire-related. Maybe a dirty/clogged air filter or fuel filter, or some condensation in the gas tank?
Old Nov 8, 2005 | 07:23 PM
Sprockets's Avatar
Default Re: Wheel balance problem, or something else? (nsxtasy)
The car runs very strong, so it's not a problem with the engine. It's a severe vibration/shudder that doesn't happen during everyday driving. The car has 300+ whp on stock axles, although I have a Quaife. Could it be an axle problem? Someone else mentioned wheel bearings. What do you think?
Regal
13
Mar 20, 2008 12:49 AM
reza"
21
May 15, 2005 01:04 PM
stivic
Dec 10, 2004 02:41 PM
grngsr01
May 8, 2003 01:53 PM
TurBoXBirD16
20
Jun 6, 2002 04:13 PM
