How to Remove GSR tranny???
Old Nov 8, 2005 | 04:59 PM
IMSTOCK's Avatar
Default How to Remove GSR tranny???
Does anyone have a link to a complete step by step on this topic??
Old Nov 8, 2005 | 05:19 PM
notanotherSC61's Avatar
Default Re: How to Remove GSR tranny??? (IMSTOCK)
Go to team- integra.net and go into the articles section. I dont believe you have to be a member
Old Nov 9, 2005 | 09:10 AM
Boosted Power's Avatar
It's pretty simple and straightforward.
Just buy a Haynes/Helms manual. It will do you good.
-Remove radiator
-Unplug harness that connects to firewall
-Remove axles
-Unbolt shift linkages
-Support engine with hoist
-Remove/Unbolt motor mounts
-Remove engine
Old Nov 9, 2005 | 09:19 AM
vaporboy12's Avatar
Default Re: (Boosted Power)
i can tell you.
1 pull axles
2. pull all the bottom bolt off the tranny including the shift linkage.
3. move to the top of the car pull all the top bolt tranny to engine bolts. leave teh top bolt in rear motor mount for the engine remove started and reverse lights connector
4. remove lower passage side toqur mount.
5.use a jack to jack the tranny up a bit and hold it in place.
6. remove tranny mount.
7.low the jack abit have a freind hold the tranny
8. you pry bar to remove tranny off dowl pins.
9. have friend hold the tranny contuie to hold it. slow remove jack.
10 get under the car with the freind and remove the tranny by wingling it till it come free and rest it on the ground.
shouldnt take you more than an hour to do this
Old Dec 1, 2005 | 02:29 PM
IMSTOCK's Avatar
Default Re: (vaporboy12)
thanks everyone. the tranny is finally out. but that dam linkage pin is no joke. i just dropped the whole linkage.
Old Dec 1, 2005 | 02:45 PM
vaporboy12's Avatar
Default Re: (IMSTOCK)
yeah those things are a bitch with a air hammer there not that bad
Old Dec 2, 2005 | 01:55 PM
JDMisGOOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">yeah those things are a bitch with a air hammer there not that bad</TD></TR></TABLE>
With the proper punch and a few whacks with the hammer it slides right out... don't know how people have issues with something so simple.
Old Dec 2, 2005 | 02:33 PM
gritsak's Avatar
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">
With the proper punch and a few whacks with the hammer it slides right out... don't know how people have issues with something so simple.</TD></TR></TABLE>
me neither...ive used a hammer/punch on several cars and never had any problem
Old Dec 2, 2005 | 04:07 PM
CoreyR's Avatar
i never understood why people have such issues. i just use a philips head screw drive thats just small enough to fit in the hole
Old Dec 2, 2005 | 04:46 PM
shortyz21's Avatar
Default Re: (CoreyR)
if you get one that has had any salt or water get in there and its old.. like from 89-93, you need an air hammer to get em out. no light tapping with a punch will take those basterds out if they havent been out in 10 years.
Civic-Kids
May 28, 2008 02:23 PM
GSR_hatch936
Feb 2, 2008 04:34 PM
96GS-R-Kaden
Nov 5, 2007 04:01 PM
hahahahhah
Aug 18, 2004 01:41 AM
0ptimus prime
Jul 17, 2004 11:17 PM
