Ciger. outlet not working on 6th gen coupe v6 (99)
Old Nov 8, 2005 | 04:48 PM
Accord9500ex's Avatar
Default Ciger. outlet not working on 6th gen coupe v6 (99)
Hi, I have recently bought a 6gen accord coupe (99). I dont' know why but my ciger. outlet is not working. I think it's one of the fuses, but dont' know which one. Anybody know? Thanks.
Old Nov 8, 2005 | 05:19 PM
Beach Accord's Avatar
get a test light, hook it up to your negative battery terminal or any good ground... and start probing the tops of the fuses (two metal spots on the top of each fuse) with the key in the on (but not running) position. If you get power on one side of the fuse and not on the other, then you have a burned fuse.
Old Nov 8, 2005 | 08:18 PM
iam7head's Avatar
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">get a test light, hook it up to your negative battery terminal or any good ground... and start probing the tops of the fuses (two metal spots on the top of each fuse) with the key in the on (but not running) position. If you get power on one side of the fuse and not on the other, then you have a burned fuse.</TD></TR></TABLE>
i think the electrical outlet is working(you can always check by sticking a power adapter for your phone or ipod to check), it just that it will not work with the ligther stud.
it's same on my accord, i think it's part of the design(that's why they have the smoker's kit from honda, to squeeze the last penny out of your wallet ) i tried my lighter stud from my other honda and from my mom's dodge van and nothing happen.
Old Nov 9, 2005 | 04:23 AM
AFAccord's Avatar
Default Re: (iam7head)
or he could just pull open the passenger fuse panel on the side of the dash and read... just seems alot easier to me if he's troubleshooting a possible blown fuse... but hey, do your own thing.
Old Nov 9, 2005 | 07:08 AM
Default Re: (AFAccord)
I try to plug in the radar dectetor. It wont' turn on, but it works in my other car. I will go to the store and buy the fuse tester..
Old Nov 9, 2005 | 07:30 AM
AFAccord's Avatar
Default Re: (Accord9500ex)
Not trying to be rude, but are you listening?? You don't need any test equipment to test for a blown fuse. It's literally 2 seconds to open your door, 2 seconds to open that panel, 10 seconds to read the diagram, and 5 seconds to pull the fuse out. If you need a test light or fuse tester to do that, then you might want to leave the whole thing to a dearlership/mechanic. If the fuse is good and you still have no power, THEN and only then you should consider a test light. Just trying to save you time and money. Don't make it any harder than it has to be.
Old Nov 9, 2005 | 10:24 AM
slvrbllt's Avatar
Default Re: Ciger. outlet not working on 6th gen coupe v6 (Accord9500ex)
i had the same problem
Old Nov 10, 2005 | 05:35 AM
deserthonda's Avatar
there are 2 fuses to chk.. under dash fuse box driver side # 8 and pass side # 9 ..if both ok, there is a 15 amp inline fuse before the cig liter relay.. chk that fuse as well
Old Nov 11, 2005 | 04:19 PM
Default Re: (deserthonda)
they both seem okay and the 15 amp is good too. god damnit. I wonder why it's not working.
Old Nov 11, 2005 | 05:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord9500ex &raquo;</TD></TR><TR><TD CLASS="quote">they both seem okay and the 15 amp is good too. god damnit. I wonder why it's not working.</TD></TR></TABLE>
next thing in line is the cigarette liter realy,, chk to see if u are getting any power on the wire going to cig liter ,,,,,if not u might have a bad relay,,if u got power , than u got a bad liter asembly
Old Nov 11, 2005 | 06:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">
next thing in line is the cigarette liter realy,, chk to see if u are getting any power on the wire going to cig liter ,,,,,if not u might have a bad relay,,if u got power , than u got a bad liter asembly </TD></TR></TABLE> Is that mean I have to open up the console to check it?
James Britt
Nov 24, 2015 08:00 AM
rhdc2itr
Jan 25, 2008 08:43 PM
sniggler316
Audio / Security / Video
Sep 2, 2007 07:58 AM
AkA_JackRisom
Feb 27, 2006 09:28 PM
timh
Dec 26, 2005 11:15 AM
