help plz car died!
Old Nov 8, 2005 | 04:20 PM
herbalist's Avatar
Default HELP PLEASE! car died!
ok so my friend was driving his eg, she started the car, drove down the street, turned right and tried shifting into second but it wouldnt go into gear, the car had shut off but her lights and music were still on.
any ideas as to what it could be
Modified by herbalist at 1:48 AM 11/9/2005
Old Nov 8, 2005 | 04:24 PM
o5mar1's Avatar
check your battery connections, make sure there tight, and also check youre grounding wires
Old Nov 8, 2005 | 04:25 PM
herbalist's Avatar
Default Re: (o5mar1)
if the battery connections were bad wouldnt the lights and music shut off too? thanks for the fast reponse
Old Nov 8, 2005 | 04:42 PM
herbalist's Avatar
Default Re: (herbalist)
anyone else
Old Nov 8, 2005 | 05:12 PM
VTAC-KAT's Avatar
Default Re: HELP PLEASE! car died! (herbalist)
sounds like she stalled
Old Nov 8, 2005 | 05:40 PM
herbalist's Avatar
Default Re: HELP PLEASE! car died! (auctionaccess)
maybe it's just me, but from my experience with driving stick shift cars, the car would still be able to start after stalling
the car does not start
Old Nov 8, 2005 | 05:42 PM
civic_driver's Avatar
check out the main relay, ignition switch and ICM/coil in the dizzy
Old Nov 8, 2005 | 05:46 PM
herbalist's Avatar
Default Re: (civic_driver)
what should i be lookin for with the coil? thanks for the help
Old Nov 8, 2005 | 05:59 PM
coquitlamEG's Avatar
you need a multimeter and a helms manual or something like that so you can start troubleshooting your ignition system. Start by checking to see if you have spark. You can pull one of the sparkplug wires and stick a screwdriver or something in it. Then have your girlfriend crank the starter while you hold the shaft of the screwdriver next to something grounded on your engine. Look really carefully to see if any blue sparks appear. Just make sure you're not touching anything metal on the screwdriver ZAP!!!!
Old Nov 8, 2005 | 08:42 PM
808_si's Avatar
yep, i second the multimeter, test the battery, alternator, and then check for spark, and fuel. they are cheap at radio shack, under ten bucks.
Old Nov 9, 2005 | 05:48 PM
herbalist's Avatar
Default Re: (808_si)
thanks for the help guys, any other suggestions?
Old Nov 9, 2005 | 06:08 PM
808_si's Avatar
let us know how the testing off all the stuff mentioned above and then we can go from there.
good luck!
E Es Won
Honda Civic (2001 - 2005)
Dec 13, 2013 05:06 PM
DO/\/\O
Jan 27, 2012 12:50 AM
captivahach
Jul 31, 2011 07:38 PM
cbstudd77
Dec 20, 2006 07:40 PM
technine
Oct 24, 2002 03:50 PM
