keeps breaking axles
From: if you build it they will come, the bottom carolina, duh
i have a turboed 1990 integra and just 2 days ago the original drivers side axle broke, i replaced it yesterday and not even two hours that same drivers side axle broke, i put another one in today; just got home from towing it;and right when i make my first turn out of the parking lot it snaps again, it is the same one part over and over, rubber joint by the tranny side..
does anyone know what is wrong. all 3 time the axles have been new?
need fixed by this friday.
i did already search.
thanks in advance
thanks in advance
how do ur mounts look like? ur motor could be shifted out of place. and thats why its snaping them. and how low is ur car? that could be the problem too
i have had a different mount in there for about a month and it just snap yesterday. its an after market one for an EF for the b16 swap. which i was told could work.
You need to have someone look at it. I think getting new motor mounts may help, but it's best to check first. Good luck... I can feel you because my axles are about to give currently, so I stay out of boost.
i try to stay out of boost but some time you just have to get the feeling of it, to me it is addicting
my teg is probly pushin about 250hp and 12psi on a little t3 super 60. the only problem is that its a DA integra. soi have to just fill my mounts with something i just cant remeber the material. i have liquid nail i just dont know if it will be to stiff for mounts. do you know what i should use to fill my motor mounts. dont want to use poly. inserts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob16EF »</TD></TR><TR><TD CLASS="quote">i try to stay out of boost but some time you just have to get the feeling of it, to me it is addicting</TD></TR></TABLE>
It can be addicting, but I have no problem driving "normally" on the streets. It's still fast enough. Plus I'm an old fart now (28 yrs. old), so I drive slower now. I even usually drive 70 on the freeway.
IVGattaBeDreaming
11
Sep 5, 2006 11:42 AM
kappa12
13
Apr 14, 2004 07:36 PM
