98 Pearl Prelude $10,000 lots of extras, loc. Cincinnati
Old Nov 8, 2005 | 12:56 PM
Cincy98lude's Avatar
Default 98 Pearl Prelude $10,000 lots of extras, loc. Cincinnati
This car has 122k on the engine, but at the same time it is in great shape. The Urithane kit was just put on this past Feb. The Front bumper, rear bumer and lip kit is all new. With the kit being Urithane that will prevent it from cracking easily unlike the cheap fiberglass kits. There is an Apexi VAFC controler installed under the stereo which will serve you well when doing mods. That is around a $600 installation. I just never got around to doing many mods. The car has been tuned for maximum power. The Dino test read that I had 180hp to the front wheels, that is much better than a stock prelude. There are also coilover installed that would allow you to lower the car even further if desired, or raise it if that were desired. The K&N True cool air intake is recharable which means that the filter never needs to be replaced. The exhaust is an APEXI 2.5 inch cat back exhaust which as im sure you know is one
of the best on the market. I just put $1700 under the hood on 04/08/2005 getting things replaced like the timing belt, tensioners, water pump, ignition wires, valve cover gasket, camshaft seal, balance shaft spring, crank seal, oil pump housing, oil pump gear, thermostat gasket......the oil has been changed every 3k miles. There is also a Sony MP3 player in the dash and a 12in. sub and amp in the trunk. I love driving this car but I just took a new job and it requires me to act/dress business professional so I cant pull up to one of my clients houses in a lowered car with a loud exhaust so it is time for me to get something more proffesional.
1988TwinCam
Aug 21, 2015 12:37 AM
Simplexity
Sep 6, 2011 06:11 AM
jd577
Jun 1, 2009 09:20 PM
Euro98ITR
May 29, 2007 08:58 AM
