Axles
Old Nov 8, 2005 | 12:16 PM
Mavrick's Avatar
Default Axles
ok, seperated using my way as there was no way in hell i could have getten a ratchet in between. Now Ive gotten the passenger axle out it came out no prob, but now the drivers axle will not come out, theres nothing holding it in so i cant figure out why? I think i will try prying lots but ive pried before quite hard with no avail.
Old Nov 8, 2005 | 12:25 PM
CRX Toad's Avatar
Default Re: Axles (Mavrick)
Are the knuckles unbolted either at the top or the bottom? Where is it stuck in the tranny of the hub? You can use a punch or something like that in the middle of the axle and use a hammer to pop it out. Can you give some more info.
Old Nov 8, 2005 | 02:40 PM
31flavorscivic's Avatar
Default Re: Axles (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Are the knuckles unbolted either at the top or the bottom? Where is it stuck in the tranny of the hub? You can use a punch or something like that in the middle of the axle and use a hammer to pop it out. Can you give some more info.</TD></TR></TABLE>
My passenger's side axle came out just fine like yours, but I also was not able to get the axle out of the hub on the driver's side of my car for some reason. I tried presses, sledgehammers, everything. I assumed that the axle and the hub became one and did not separate. As I had to get new hubs anyways this wasn't too bad, as I ditched the old one because I had to change axles, but I sure hope it doesn't have to come to that with you.
Old Nov 11, 2005 | 12:25 AM
Mavrick's Avatar
Default Re: Axles (31flavorscivic)
****, upon axle removal one of them popped out of its socket, but I popped it back in, is that bad?
Old Nov 11, 2005 | 10:04 AM
Mavrick's Avatar
anyone?
freshvibes
Nov 23, 2007 07:54 AM
transpar_nt
22
Apr 2, 2006 03:37 PM
rasinhell
Jan 13, 2005 09:52 PM
stealthhatch
Mar 21, 2004 09:20 AM
tecnic1
Jul 11, 2003 07:23 PM
