93 CIVIC HELP! My Stearing Seems To Have A Mind Of Its Own please read thank u....
Old Nov 8, 2005 | 10:22 AM
sean555's Avatar
Default 93 CIVIC HELP! My Stearing Seems To Have A Mind Of Its Own please read thank u....
Hi i have a 93 civic with a gsr motor swap, i have New lowering spings and gas shocks, I stopet driving my car to day because when ever i put my foot down on the clutch or put in nutole my stearing seems to have a mind of its own it shakes and pulls hard to one side, than goes back where it was, than pulls to the side agine it keeps doing that vary fast and pulls my hand prity hard when griping the stearing wheel......BUT when im driving and giving it gass it doesent realy doo it... only when the clutch is down like when braking and shifting grears it realy shakes... HAS ANY ONE HAD THIS PROBLEM? OR MIGHT KNOW WHATS WROUNG?
THANKS FOR YOUR TIME
Old Nov 8, 2005 | 10:24 AM
duggy's Avatar
Try getting it aligned at an alignment shop.
Old Nov 8, 2005 | 10:43 AM
Slow EJ8's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">Try getting it aligned at an alignment shop. </TD></TR></TABLE>
Try that ^^^ and also maybe have the tires rebalanced.
Old Nov 8, 2005 | 10:51 AM
92ehatch's Avatar
Default Re: (Slow EJ8)
do it ASAP or you want have tires to rebalance
Old Nov 8, 2005 | 10:55 AM
duggy's Avatar
Also try to see if one of your brake calipers are siezed. That would cause your car to pull to one side but you also said it only does it when you shift. Check the axles maybe?
Anyways, check the balance of your tires. I had a blowout on the freeway one day and the tires weren't balance. Almost killed myself -_-
Old Nov 8, 2005 | 11:03 AM
Mohsin's Avatar
It could be the the Lower Tie Rod Ends, but the "steering moves by itself" happens only when driving, yours seems to do stationary?
Old Nov 8, 2005 | 11:33 AM
sean555's Avatar
thanks yea my buddy thinks one of my axles is shoot... how do u tell? also how do u tell if your brake calipers are siezed? seems to be a biger problem than just a unblanced tire or bad alignment....
chikichimo
Oct 29, 2012 08:17 PM
supamanRicer
Dec 4, 2006 07:56 PM
mwagner44903
12
Jul 29, 2005 08:48 AM
EsCo_EsCo
14
May 30, 2004 04:30 PM
