1988 Honda CRX SI with a Battery that will not charge
The titler says it all. I have a 1988 Honda CRX. I have replaced the battery and the alternator and I am unable to get the battery to charge when I am driving. Any suggestions?
Check all cables, look for any loose connections. Sounds like you either have something draining your battery or you need to go over everything with a fine tooth comb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">Check all cables, look for any loose connections. Sounds like you either have something draining your battery or you need to go over everything with a fine tooth comb. </TD></TR></TABLE>
I'd agree
normally i'd look for a drain over a comb though.
I'd agree
Cryptopsy
Aug 13, 2005 04:04 PM
