Mant Required
How do you reset the maintence required light? i dont have the owners manual and need to figure this out asap. already searched and people said it was in the manual. but since i dont have one i just need a quick step through
since this is in the Accord forum, I assume this is for an Accord? But since you don't have an Accord listed in your sig, I don't know what year your refering to.
If it's for the 94-97 Accords, there is a button that you push in the bezel area. It has a rectangle shaped slot that you slide your key into and then press the button.
If it's for the 98+, I don't remember the procedure but I'm sure it was different than the 94-97.
Sorry if I wasn't much help.
Hold down the button you use to reset the odometer, then insert the key and turn it 2 clicks (accessory switch) and continue to hold the button for about 15 seconds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jake15348 »</TD></TR><TR><TD CLASS="quote">Hold down the button you use to reset the odometer, then insert the key and turn it 2 clicks (accessory switch) and continue to hold the button for about 15 seconds.</TD></TR></TABLE>
nope, sorry, try again. "ON" position, not accessory. 2 clicks was right though.
wcat98
11
Mar 11, 2023 11:32 AM
accordlx1998
Apr 22, 2005 08:24 PM
for trying
