Suspension & Brakes Theory, alignment, spring rates....
ITR Sway Bar on EJ8 With Omni LCA's
Old Nov 8, 2005 | 07:56 AM
Tru's Avatar
Tru
Default ITR Sway Bar on EJ8 With Omni LCA's
Ok, first off...i did search, and didnt find out exactly what i wanted.
I ordered a USDM ITR 22mm Rear sway bar for my EJ8. i currently have Omni Power Rear lower control arms(old ones w/ stars), and when i was searching, i found that they many people have run into problems with this setup. if i sell the ITR one, and get a CTR one will i have the same problem? Is there any other way i can run the ITR bar w/ the omni power lca's? And also, will the bar actually hit my LCA's(this happened to my friends car)? Thanks in advance.
Nick
Old Nov 8, 2005 | 09:49 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ITR Sway Bar on EJ8 With Omni LCA's (Tru)
It will fit perfectly. You will, however, have to use your Si end links to connect the 2mm bar to the Omni LCAs. To make it work, you will need a set of custom aluminum bushings (pictured below). Otherwise you won't be able to bolt your Si endlinks onto the Type R bar.
A-Spec Racing makes these, so give them a call. Their cool guys with great products...
Old Nov 9, 2005 | 10:22 AM
Tru's Avatar
Tru
ok, cool. If i get a CTR sway bar, will i have the same problem?
Old Nov 9, 2005 | 10:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Tru)
I don't know...
be.twenty
Suspension & Brakes
12
Sep 3, 2005 03:30 PM
. o 69 o .
Suspension & Brakes
40
Aug 23, 2005 09:49 PM
BLUE EH3
13
Jun 8, 2005 06:18 PM
01geeser
May 9, 2002 05:04 AM
tFUnK
18
Feb 8, 2002 11:24 AM
