traction on boosted Si
Old Nov 8, 2005 | 07:00 AM
goldenvizion's Avatar
Default traction on boosted Si
I need advice to get some traction on my Si. I have 312whp & 265lb.ft. of torque @15lbs. of boost. I know that a LSD and some traction bars are probably the best option, as well as upgrading the suspension alltogether ( no suspension mods ). If anyone has advice on a good setup, let me know. What should be the steps in what to buy first, since my budget is limited?
Old Nov 8, 2005 | 07:12 AM
hdel22a's Avatar
Default Re: traction on boosted Si (goldenvizion)
what kind of tires are u running on..?
Old Nov 8, 2005 | 07:20 AM
huntarrr's Avatar
Tires, slicks, suspension, traction bars, lsd would all help. Really depends on what type of driving you do. Track, drag, daily, etc.
Default Re: traction on boosted Si (hdel22a)
yokohama AVS ES100's - I could put a drag radial on the power wheel, but i get no traction through third...
Old Nov 8, 2005 | 07:21 AM
mostly a daily driver, but i like to drive hard- and it's no fun when you got to let off the gas...
Old Nov 8, 2005 | 12:27 PM
black_EM1's Avatar
Community Builder
Community Influencer
A LSD should your first priority. Along with, as stated earlier drag radials. Or flat out slicks if you're dragging
Old Nov 8, 2005 | 12:50 PM
NoBottleJustThrottle's Avatar
Default Re: traction on boosted Si (black_dohc)
Suspension mods should of been done by now with that much power in my opinion. But thats just me.
Like stated above though, LSD will be a huge help, traction bars, coilovers, motor mount inserts, good tires. Basically you want that power to be put to the ground smoothly. That means tryin to get the flex out of your chasis and minimizing motor movement. Its still going to be a bitch to launch your car...but that should be expected with FWD unless you are on slicks.
oneludesol
Jan 10, 2009 10:21 AM
sporkcrx
Mar 28, 2005 08:23 PM
Kp_VtekNiks
May 1, 2003 10:16 PM
sonicSVT
Jan 6, 2003 05:15 AM
Boostless97Lude
Oct 1, 2002 09:29 AM
