Neuspeed sport springs
i just got a set of neuspeed sport springs for my 5th gen prelude the numbers on the box are different from the numbers on the springs does anyone have the numbers on there springs to see if these springs i got will work??? the numbers i have are 55.20.17F-front 55.20.16R-rear
Did you buy them new? Or did you buy them from someone? I would suggest you calling neuspeed to see......atleast email them. They'll be able to help you way quicker than we can.
i called neuspeed they said these are the springs for them. but it lowers the car like 4 inches instead of the 1.75 and 1.5 inches. they said if cut the bump stops it would cause it to lower the car to the 4 inches that not posible.
you've tried the springs on your car? they lower it 4 inches? wow. i cut my bumpstops in half for my neuspeed sports and they were right where they're supposed to be.
you try putting all 4 corners on springs? maybe you put the springs on backwards so end was real low and the other real high.
in case you haven't distinguished between front and rear:
the fronts should be short and should have equal spacing between all the coils. the rears are longer and have large spaces in the coils at one end and small spaces in the coils at the other end.
i can see the lenght of the spring i know that but i would like to know if anyone has the same springs on there car as i do with the same part number i posted the first time
i dont think those are for a prelude. look here
http://www.neuspeed.com/catalog/1Suspension.pdf
it says that those part# are for a EG, and that it will lower 1.8f 1.6r. sorry dude.
I don't get it - so you haven't installed the springs yet?
If you're just measuring the springs with stock side by side (off the car) there's no way you can tell accurately.
Neuspeed does change product numbers from time to time just like anybody else but you talked directly with Neuspeed DIRECTLY right? and Neuspeed said it would fit?
I'm also not seeing this 4 inches thing. The chassis would be on the ground with a 4" drop. The springs would have to be ridiculously short or incredibly soft.
neuspeed sport springs will not work on a 01 base prelude. the springs they send in the kit will not lowwer the car! the front are not right and the rear springs are the same lenght as the stock springs. the springs they sent are 55.20.17f and 55.20.16r yes i know what these springs say they got to but newspeed said they make a kit for the prelude and i am here to tell everyone they have not worked for me yet. so im looking for a set of ground control coilovers is anyone has a set for sale let me know thanks
