Suspension & Brakes Theory, alignment, spring rates....
My proposed suspension setup, good or no?
Old Nov 8, 2005 | 05:03 AM
Boosted4's Avatar
Default My proposed suspension setup, good or no?
Hey all,
I posted this as a reply to my post in the Forced Induction section, but wanted to get some opinions on if I am going the right route or not. Car is a 95 del Sol SI, dropping in a built B18C, anywhere for 300-600 hp, depending on what i run it at. Its going to be mostly a street/drag car, maybe a couple of auto-x's to try it out. What do you think of this? I read alot of the posts on here about the Koni/GC setup being better than the other options. What rates should I get?
I am thinking:
Koni Yellow Sports w/ Ground controls
Energy Suspension Hyperflex kit
Megan Racing LCA's
Megan Racing Upper Front Strut Bar
Megan Racing Upper Rear Strut Bar
Megan Racing Lower Rear Tie Bar
Oh, and I am considering a L-Con traction bar. Not sure if I will need it.
I considered Tein SS's and Buddy Club N+, but i heard good things about the Koni/GC setup.
Thanks,
Darrell
Old Nov 8, 2005 | 06:56 AM
AutoXer's Avatar
Default Re: My proposed suspension setup, good or no? (Boosted4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted4 &raquo;</TD></TR><TR><TD CLASS="quote"> the Koni/GC setup being better than the other options. What rates should I get?
Yes, it is. Go with the standard rates for now, and you can always change them as you decide what's best for you.
Megan Racing LCA's
I'd save your money. These parts don't do much; and you can get eBay bars that are nearly identical for pretty cheap.
amej8
Suspension & Brakes
Jan 28, 2006 08:14 PM
badfish4025
Jan 19, 2006 01:49 PM
nabisco
Nov 18, 2004 11:49 AM
Blind-Fashion
13
Oct 21, 2004 10:13 AM
temp
18
May 3, 2004 07:25 PM
