What cam to use that makes good power?
what's up guys i was thinking about changing my cams for something bigger what would you guys prefer is a good cam to go with that makes good power i was thinking of skunk's stage 2's what do you guys think?????
thanks.
thanks.
running b16 swap with inline pro springs, retainers, skunk 2 cam gears, right now running jdm itr cams. skunk 2 intake manifold. soon valves too. This is the setup now.
just looking for a bigger cam to run for a while what's good to go with at a decent price.
Bump your compression up a bit, and make use of some of the bigger cams on the market.
Try Skunk2 Pro1's, Buddy Club Spec 4's, Rocket M22x, etc...
- Derek
- Derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">m22x, or m22xx</TD></TR></TABLE>
sorry to somewhat steal thread but are would the m22xx be fine in a b18c1 with a milled head, thin head gasket with the stock pistons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">man i would really like to try a set of these rocket cams you guys speak reall y high of them </TD></TR></TABLE>
Would you like me to have Rocket contact you Chris?
As for the use of M22's: we recommend a minimum of 11.5:1 compression on 1.6 and 11:1 on 1.8 liter motors.
stock compression on an itr motor is wut 10.4:1??? would a thinner head gasket like a mugen one be enough to bump it up to 11?? and your are talking bout the m22xx right??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">Bump your compression up a bit, and make use of some of the bigger cams on the market.
- Derek</TD></TR></TABLE>
Can i run the skunk's stage 2's on a stock headgasket and bottom end without damgaging anything.
cool thanks i found some stage 2's for a good price new so i might run those for a while and keep my other cams and see what kind of power difference i made on the dyno this time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecgod »</TD></TR><TR><TD CLASS="quote">cool thanks i found some stage 2's for a good price new so i might run those for a while and keep my other cams and see what kind of power difference i made on the dyno this time.
keep us updated. Post up dyno graph once you compare them.
</TD></TR></TABLE>keep us updated. Post up dyno graph once you compare them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">
keep us updated. Post up dyno graph once you compare them.</TD></TR></TABLE>
Ok i am going to try to dyno it soon but still have alot of motor work to do first. The motor is not even back in the car yet but i keep you'll updated made pretty good power on my first dyno for being pretty much stock.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">
As for the use of M22's: we recommend a minimum of 11.5:1 compression on 1.6 and 11:1 on 1.8 liter motors.</TD></TR></TABLE> yes please i know he is busy but if these cams work well i will carry his line
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote"> yes please i know he is busy but if these cams work well i will carry his line </TD></TR></TABLE>
you wont be dissapointed
