shift knob rattleing.........
Old Nov 8, 2005 | 12:01 AM
hlee5363's Avatar
Default shift **** rattleing.........
i have a 98 gsr... i just put on polyurathane shifting bushings... and ever sine i put that on today.. my shiftknob rattles... it doesnt rattle like constantly... only when im flooring it... when i hit about 7500 -8000 rpm it starts rattleing like crazy and its loud as hell... why would this be???? BUMP
Old Nov 8, 2005 | 12:11 AM
Outkast95LS's Avatar
Default Re: shift **** rattleing......... (hlee5363)
Is it the whole shifter thats rattling?Maybe the shift linkage is hitting your exhaust? Can't really say, just try to pin point where the sound is coming from.
Old Nov 8, 2005 | 12:16 AM
BSP-DC2
Guest
Posts: n/a
check below your shifter where it pivots to see if theres any markings on it
Old Nov 8, 2005 | 12:39 AM
.water's Avatar
get your *** under the car and check it out. for lossen bolts, touching other parts, bent, busted brushings.
Old Nov 8, 2005 | 07:12 PM
hlee5363's Avatar
thanks.................. the sound is comming from the shiftknob... when i hoold the shift **** VERY tight... it doesnt make a noise but i can still feel the vibration...
Old Nov 8, 2005 | 08:26 PM
f2rider's Avatar
Mine does the same thing. I haven't been able to figure it out yet. I have a tsudo short shifter, I guess its a skunk 2 knockoff.
Old Nov 8, 2005 | 08:31 PM
debogsr's Avatar
Default Re: shift **** rattleing......... (f2rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hlee5363 &raquo;</TD></TR><TR><TD CLASS="quote">thanks.................. the sound is comming from the shiftknob... when i hoold the shift **** VERY tight... it doesnt make a noise but i can still feel the vibration...</TD></TR></TABLE>
that does not mean its coming from the shift ****.
Take the shift **** off the car, and drive... If it rattles, its not your shift ****. Check under the car...
Old Nov 9, 2005 | 12:17 AM
debogsr's Avatar
Default Re: shift **** rattleing......... (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f2rider &raquo;</TD></TR><TR><TD CLASS="quote">Mine does the same thing. I haven't been able to figure it out yet. I have a tsudo short shifter, I guess its a skunk 2 knockoff.</TD></TR></TABLE>
You my friend have a short shifter rattle. Annoying as hell. I had a machine shop drill out my pivit point in the SS to make it a little bigger and then i used 4 thick O-rings and it got rid of it. The hole that mine came with was smaller than stock and it eliminated that plastic sleeve between the pin and the shifter pivot hole.
SOooooo, yeah, i drilled that out and works great with no rattle. =0]
the more i think about it, It is definitly not your shift ****. Unless you have some really cheap aftermarket **** that doesnt thread into the shifter.
Any word on the diagnoses???
Old Nov 9, 2005 | 12:20 AM
Greddy Dantegra's Avatar
your shifter.... if you have a short shifter or not.... where its connected to on the shift linkage.... you should be able to see it when u get underneath the car... the screw, pin, nut, bolt howeever u want to call it might not be tighten all the way... go get it checked out...
Old Nov 9, 2005 | 01:21 AM
greasemonkee's Avatar
Default Re: shift **** rattleing......... (dvs gsr)
I had a short shifter that would hit its resonance at 7900-8200. I put the stock shifter back in and the resonance is lower at 7000 to 7800ish. Ever paid attention to what the shifter feels like when it vibrates like that? You can hardly feel it. I got aluminum flywheel and solid mounts though.
Old Nov 9, 2005 | 11:29 AM
RevOnRacerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">
Take the shift **** off the car, and drive... </TD></TR></TABLE>
that just sounds silly...
Old Nov 9, 2005 | 11:51 AM
debogsr's Avatar
Default Re: shift **** rattleing......... (RevOnRacerz)
haha, why? You dont need one to drive.
Old Nov 9, 2005 | 12:08 PM
Muckman's Avatar
Moderator in Chief
Its normal. The poly bushings are going to translate more vibration. Thats the compromise for less flex.
Old Nov 9, 2005 | 02:56 PM
jessec's Avatar
Default Re: shift **** rattleing......... (Muckman)
speaking from knowing a guy that just built up his type-r.. get hasport engine mounts.. his engine doesn't move, no vibration to the shifter.. it sits amazingly still.. mine rattles like a bitch still.. b&m short shifter
it's just the engine shaking, transferring the rattle to the shifter..
engine mounts expensive fix, but works like a charm, and less engine shaking :D
marc100
19
Jun 25, 2012 04:33 AM
civic92si
Jun 5, 2012 09:16 PM
egvtec
12
Feb 1, 2006 12:53 PM
loclowd
Oct 10, 2005 11:40 AM
pr0jektdc2
Dec 19, 2002 06:30 AM
