Installed headers... now car seems to be running cold
Old Mar 9, 2002 | 08:35 PM
1996GSR's Avatar
Default Installed headers... now car seems to be running cold
As the topic states, I installed a DC 4-2-1 header a few days ago. No exhaust leaks detected by me, and its definitely not too loud (which I've heard some people say is a sign of an exhaust leak). Anyway, I notice that my temperature gauge doesn't read as hot as it did before the header install. If I gun the engine the gauge will read hotter, but when I'm cruising on the freeway, the gauge is about 1/8 to the red zone on the gauge, and the gauge just seems to read lower in general. My question, is there anything specific to the header installation that could cause this? Thanks much.
Old Mar 9, 2002 | 08:39 PM
dirtySOHC's's Avatar
Default Re: Installed headers... now car seems to be running cold (1996GSR)
i dont know why it would be related.
did you reset your ECu after the install?
Old Mar 9, 2002 | 08:43 PM
1996GSR's Avatar
Default Re: Installed headers... now car seems to be running cold (dirtySOHC's)
Yea, reset the ecu after the install.
Old Mar 9, 2002 | 08:49 PM
sorry man dont know wat to tell you. i am not too familiar with this type of problem. i am sure someone here will know
Old Mar 9, 2002 | 09:19 PM
SPOCK's Avatar
New User
headers have nothing to do with the cooling system. check your grounds. might be a electrical thing.
Old Mar 10, 2002 | 11:15 AM
1996GSR's Avatar
Default Re: Installed headers... now car seems to be running cold (SPOCK)
Thanks for the advice. At least I know now there isn't something I may have disconnected.
Old Mar 10, 2002 | 11:41 AM
Kamin's Avatar
yea a header dosent have anything to do with cooling unless (dont know HOW) you hit the thermostat or somthing. thats very difficult to do with a header install
i dont know why you would be worried. heat=wear.
check your cooling lines and ****.
Old Mar 10, 2002 | 03:00 PM
Zeus Zore's Avatar
Default Re: Installed headers... now car seems to be running cold (KAMiN)
!?! heat = wear ??!?! (yes hot not good but) well running 2 cold is not good 2 !!!!
i dont like the fact that you have so much reading ... should stay the same, driving or still.... you should try and change you colling regulator !! and fluid !!!
Old Mar 10, 2002 | 05:55 PM
Rob Dizzle's Avatar
Default Re: Installed headers... now car seems to be running cold (Zeus Zore)
this is expected
if you are having better air flow, the heat from the exhaust is going out alot better
when i installed comptech header, n' exhaust and high flow cat, my engine is running way cooler
the acura gauge does large increments on the water temp. you arent running that much cooler
not sure about life of the engine being extended, but it definetly isnt worse
i think the term is called heat scavveging
on turbo cars, part of the reason when they run a test pipe, is because the heat and exhaust flow is much improved, thats partly why they gain sum more power
even91civic
Jul 22, 2004 01:20 PM
FusionITR
Mar 13, 2002 07:48 PM
AL
Jan 3, 2002 07:16 PM
