fog light wiring question ( I Searched)
OK so i wired the outside harness and went to work on the inside harness, I ran into some problems, one i cant find the one pin connector where the brown pin from the fog light harness connects to, I searched for the dam connector for like 30 minutes and could not find it. Also, the fog light wiring harness comes with two plugs that are off white. Do those plugs plug together, in confused because the instructions say disconnect the headlights connector, why do i have to do that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge99hx »</TD></TR><TR><TD CLASS="quote">OK so i wired the outside harness and went to work on the inside harness, I ran into some problems, one i cant find the one pin connector where the brown pin from the fog light harness connects to, I searched for the dam connector for like 30 minutes and could not find it. Also, the fog light wiring harness comes with two plugs that are off white. Do those plugs plug together, in confused because the instructions say disconnect the headlights connector, why do i have to do that? </TD></TR></TABLE>
1st question. Are you talking about the one that was blue taped? That connector is hard to find, but it's up there. Just get a flashlight and move stuff around until you see it.
The two offwhite plugs don't connect to eachother. Disconnect the headlights connector and each of the plugs go to those connections.
You probably already have this but here it is again anyways: http://www.handaaccessories.co...s.pdf
If you have any more questions you can PM me or post again in here and I'll try to help.
Filliam H. Muffman
Dec 1, 2003 07:00 PM
