Rear Disc Problem
Old Nov 7, 2005 | 07:58 PM
Rukusmasta2's Avatar
Default Rear Disc Problem
so here im bolting everythign up and the bolt on the bottom that holds LCA's that brakes that goes around doesnt fit right, the civic is wider there and i have to bed out the bracket i guess, any one else have this problem while doing this
Old Nov 8, 2005 | 03:06 AM
civickiller's Avatar
Default Re: Rear Disc Problem (Rukusmasta2)
did you swap the whole trailing arm or did you take apart the rear drums ?
Old Nov 8, 2005 | 01:49 PM
Default Re: Rear Disc Problem (civickiller)
swapped out whole arm
Old Nov 8, 2005 | 02:03 PM
EL Vap133's Avatar
Are you using your stock LCAs?
Old Nov 8, 2005 | 06:21 PM
Default Re: Rear Disc Problem (EL Vap133)
i used my stock lca when i did my rear disc swap. everything fit fine
Old Nov 9, 2005 | 07:06 AM
yea stock civic LCA's its like there a lil bit wider or some **** im liek WTF
Old Nov 9, 2005 | 09:10 AM
Deo's Avatar
Deo
What year is your car, and what year/model did the discs come from?
There are 2 differant kinds of LCAs, though as far as I know, they both bolt up the same.
Old Nov 9, 2005 | 12:14 PM
vegaskurt's Avatar
Default Re: Rear Disc Problem (Deo)
The LCA's are near identical in length, maybe a mm or two but that can be made up in the bushing. Only difference is the position of the shock mount.
89 civic HB DX and came off 90 Acura
Old Nov 9, 2005 | 12:15 PM
89 Civic HB DX and cam off of 90 Acura integra 4 dr
Old Nov 9, 2005 | 12:17 PM
thats exactly where its bigger is at the bushin where it bolts up
brownsEF
Feb 27, 2010 07:01 PM
Cory Matthews
Suspension & Brakes
10
Oct 4, 2007 08:27 AM
Type V
Suspension & Brakes
14
May 8, 2006 04:57 PM
khmershadow
Mar 13, 2005 01:58 PM
func-tion
13
Feb 9, 2004 10:24 PM
