How do u remove the interior dash vents?
The center and the 2 on the side? i tried using a screw driver to pop it out but i didnt want to use too much force and break it. Is there a special way of doing this?
the center vent , just use the screw driver like you were doing and pull on it also in the center of the 2 vents. the outsides im not too sure about, probably just pry a little bit and pull also. should come right out.
yea you would have to get a flat head and pop it out..that what i do when ever i wanna take them out..cause the have a snap in clip that hold it on the side and top and bottom from falling out. the other way is if you have the dash out already then just look behind it and push it out..
